Warning message
Leo Laohoo Sat, 02/25/2012 - 14:14
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
In ROMmon, use the command "format flash:".  The CF you are using is either not formatted correctly, failed or the CF slot has failed.
When you are done with that, follow this proceedure:  How to Download a Software Image to a Cisco 2600 via TFTP Using the tftpdnld ROMMON Command
antonkolev Sun, 02/26/2012 - 20:34
I figure out the problem-  256 MB DRAM card maybe was faulted-- I was in the process to install more flash and more RAM - I change 3-4 compact flash cards- the same problem ,but when I remove the RAM card - the router booted normally
I tried to put the faulted card on different 1841 router and had the same problem including some ASCII code
I see you suggested to go in ROMMON mode- but the router even doesn't go to ROMMON mode
Anyway the problem is resolved and THANK you very much for your resonse
For other people with this or similar problem - check your DRAM card if you have one installed
