CTIOS Cli
Feb 26th, 2012
  • Gold, 750 points or more
I am facing a problem that the statistics for the agent in the CTIOS client is empty , the skill group statistics are showed normally but the problem is only with the Agent statistics , if i use CAD i can see the statistics the problem is only with the CTIOS client, Any idea what is happening ?
UCCE is 8.0(3) ES33
Amer
Amer rajai Sha'er Mon, 02/27/2012 - 03:20
Hello Anand,
Unfortunatly it didn't help , i already tried to update the polling interval without luck.
Amer
tony.heaney Thu, 03/14/2013 - 11:18
Did you find a resolution for this?  I am experiencing the same issue with CTIOS 8.5.3.
Senthil Kumar Sankar Thu, 03/14/2013 - 20:18
  • Cisco Employee,
Hi Tony,
Can you check what do you have in the registry value set for the below two in CTIOS serve
[HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems,Inc.\Ctios\CTIOS_ \CTIOS1\Server\Agent]
1) PollForAgentStatsAtEnd Call
2) PollingIntervalSec
Just make sure those values are set as default as given in the CTIOS System Manager guide
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/ctios/ctios8_0/installation/guide/cti80smg.pdf
Senthil
sandeep chauhan Thu, 03/14/2013 - 23:49
Hi Amer,
Can you post the registry snapshot of the loaction
"[HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems,Inc.\Ctios\CTIOS_ \CTIOS1\Server\Agent]"
Sandeep
Related Content
