Cisco 3550 IOS - VLANs and SNMP for Network Traffic Issue
Feb 26th, 2012
I am just starting out learning Cisco with my web hosting company I just started in December.  I am having an issue with VLAN interfaces not recording traffic though SNMP I am using Cisco IOS EMI 12.1.  Cacti usually shows an empty white space or a little traffic here and there.  But I don't think it is an issue with cacti.  Running layer 3/static routing on this vlan interface.  Below is show int Vlan command (in case its usefult to resolve my issue):
edge2.dtw1.d10net.net#show int Vlan51
Vlan51 is up, line protocol is up
  Hardware is EtherSVI, address is 0016.c739.af80 (bia 0016.c739.af80)
  Internet address is 208.79.208.150/29
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Last input 00:00:01, output 00:00:20, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     601314 packets input, 54012452 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicast)
     596830 packets output, 52053177 bytes, 0 underruns
     0 output errors, 0 interface resets
Please advise what I need to do or what I am doing wrong again I am a newbie.
Sean Butler
D10host
Owner
