Etherchannel issue with netapp
Feb 27th, 2012
I have an etherchannel configured on a cat6k to connect to a netapp. the ints in the channel group are up but the port channel is down. when i do a show etherchannel summary it show that the ports are in portchannel 12A not 12. Any ideas
the config is attached.
acampbell Mon, 02/27/2012 - 03:37
  • Green, 3000 points or more
Looking at this link seems to infer that there is some difference between the 2 physical ports.
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a0080094470.shtml#po1a
I do not see what is is.
May be show interface might point to the issue
A second prt channel xxA is created by lacp when discrepencies are found in the original xx channel group
Alex
Marcel Zehnder Mon, 02/27/2012 - 09:26
  • Bronze, 100 points or more
In addition check the version of the netapp device - Last week I had similar issues with a netapp device. The solution was a software upgrade on the netapp-filer.
regards
Marcel
Devavrat Oka Wed, 05/23/2012 - 11:58
Can you paste an ifconfig -a output from the netapp controller here?
