Off-Hook Alarm in CME
Feb 27th, 2012
Looking for a way in CME to do Off-Hook alarm to an emergency number.
For example, If a end user takes an IP Phone off-hook but does not dial any digits, then after the first digit timer expires, we want the phone to ringdown to the front desk at the location.
has anyone come accross a way to accomplish this in CME?
regards,
cj
ronpatel Mon, 02/27/2012 - 23:25
  • Blue, 1500 points or more
You may use trunk configuration in ephone-dn
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_t1ht.html#wp1015411
You can try using exact steps in above link or try below configuration.
#ephone-dn   �� the phone that you need this feature
  Trunk 132878  timeout seconds �� external number
#dial-peer voice
Destination-pattern 132878
Port 0/0/0:15
Forward-digit all
Ronak Patel
cjoseph23 Tue, 02/28/2012 - 07:02
Thanks Ronak,
I will try this configuration in the lab and let you know how it goes.
Paolo,
I have never seen this feature either but I did go onsite and had them show me this is currently working.  If they go off hook with the digital set, don't press any digits, then after the first digit timer runs out the phone will dial the emergency center which is located onsite and connected to the same PBX.
I believe the PBX is a Siemens 390.
Cyril
Paolo Bevilacqua Tue, 02/28/2012 - 23:57
  • Hall of Fame,
    Founding Member
Yes we can run in the occasional odd feature configured on some legacy system, but the question is, is that really needed? Or do we have to carry over stuff just because it was there and useful in the mind of someone that is not even in charge anymore ?
cjoseph23 Wed, 02/29/2012 - 06:49
Unfortunately it is a required feature to carry over.  We look at all the features they currently have and only ported over the ones which were deemed critical.
The Health/Safety commission at this location has placed this feature as one which is needed.  I did demonstrate the feature to them via CUCM with blank translation patterns and uncheck the urgent priority.  But what happens in a SRST type scenario?  This is why i am researching for a CME option to this feature.  I am required to show that in any scenario (CUCM, CME,  SRST in CME) this feature will be available.
I will try the above recommendation and report back.
thx
cj
Paolo Bevilacqua Mon, 02/27/2012 - 22:14
  • Hall of Fame,
    Founding Member
It might be possible to do that , but I haven't seen this on any of PBX system I've seen in the world.
Related Content
