Block connection to real server in CSS
Answered Question
Feb 28th, 2012
HI
Is there anyway i can block connection to a specific server in CSS serverfarm without suspending and retaining the existing connections to that server?
Shanil
Correct Answer by Daniel Arrondo Ostiz about 5 years 5 months ago
Hi Shanil,
Yes, suspending a service will stop new connections but not break the ones already established.
After suspending the service, you can check the amount of connections still present on that service with the "show service" command. Once the "Current Local Connections" counter reaches 0, you can go ahead with the maintenance without causing any impact.
Daniel
Overall Rating: 5 (1 ratings)
Daniel Arrondo Ostiz Tue, 02/28/2012 - 07:01
  • Cisco Employee,
Hi Shanil,
The way to stop sending new connections to a server is suspending it. Anyway, suspending a service will not affect the connections already established on it, those will will continue to work.
Why do you want to block these connections without suspending the service?
Daniel
shanilkumar2003 Tue, 02/28/2012 - 08:26
Thanks Daniel..
There is a requirement for application to do not make new connections during some maintenance.
So if i suspend a real server all the established connection are still serve to the same server and will not establish new connections right? how can i see the established connections with sh service ?
Correct Answer
Daniel Arrondo Ostiz Wed, 02/29/2012 - 01:00
  • Cisco Employee,
Hi Shanil,
Daniel
shanilkumar2003 Wed, 03/07/2012 - 11:50
Thank you very much daniel..i have successfully completed the activity
Shanil
