ACE serverfarm fail-on-all option missing
Answered Question
Feb 28th, 2012
- Platform: ACE 4710 software A3(2.7)
- Problem:
ACE(config)# serverfarm host HOST-FARM
ACE(config-sfarm-host)# ?
Configure host serverfarm:
  description        Configure description string for serverfarm
  do                 EXEC command
  end                Exit from configure mode
  exit               Exit from this submode
  fail-on-all        Fail reals when all probes fail
  failaction         Configure action to be taken on rserver failure or removal
  no                 Negate a command or set its defaults
  partial-threshold  Configure partial-threshold % to deactivate the sfarm
  predictor          Configure Load Balancing Predictor Algorithm for the server
ACE(config)# serverfarm redirect REDIRECT-FARM
ACE(config-sfarm-redirect)# ?
Configure redirect serverfarm:
  do           EXEC command
  predictor    Configure Load Balancing Predictor Algorithm for the serverfarm
  probe        Associate probe with sfarm
  rserver      Associate server with serverfarm
Why is the fail-on-all option missing from the serverfarm that is of type redirect? This option is something that I would actually need in a certain situation.
Correct Answer by Jorge Bejarano about 5 years 4 months ago
Hello Timo,
As per checking on different release notes, what you are looking for seems to be not available on any release notes currently.
Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
Jorge Bejarano Thu, 03/01/2012 - 16:53
  • Silver, 250 points or more
Hello Timo,
Jorge
