Two SIP Trunks
Feb 28th, 2012
  • Blue, 1500 points or more
Hello its configure two SIP Trunks in the same router, because i only have one sip-ua on the router to configure.
I using this IOS : Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
Leonardo Santana
Chris Deren Tue, 02/28/2012 - 07:45
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Leonardo Santana,
You can simply use session target on the dial-peer rather than the sip-ua.
HTH,
Chris
Leonardo Tadeu Tue, 02/28/2012 - 08:48
if i need to use the SIP UA, for the authentication for the ITSP?
Chris Deren Tue, 02/28/2012 - 09:01
  • Hall of Fame,
You can do that at dial-peer level as well. Check out
Configuring Multiple Registrars on SIP Trunks
http://www.cisco.com/en/US/partner/docs/ios-xml/ios/voice/sip/configuration/15-1mt/Configuring_Multiple_Registrars_on_SIP_Trunks.html
HTH,
Chris
