bi-directional nat ok, tcp failing
Answered Question
Feb 28th, 2012
  • Purple, 4500 points or more
For the life of me I can't get his one working. Public IP range is 1.1.1.128 255.255.255.128 and internal networks are 10.1.3.0 /24 (servers) and 10.1.7.0 /24 (clients). I have a static NAT translation so outside users can access an internal web server. I have another NAT statement for bi-directional NAT so inside users can access the web server using it's public IP. Outside users work fine. Inside users don't when pointing to public IP, but when pointing to the internal, it works just fine.
Client IP: 10.1.7.100
Server Private IP: 10.1.3.77
Server Public IP: 1.1.1.177
Looks like the NAT translation is working just fine-
Feb 28 2012 12:11:21: %ASA-6-302013: Built outbound TCP connection 3343090 for outside:10.1.3.77/80 (1.1.1.177/80) to inside:10.1.7.100/1221 (1.1.1.254/49099)
But we can see that the TCP session never establishes-
Feb 28 2012 12:11:51: %ASA-6-302014: Teardown TCP connection 3343090 for outside:10.1.3.77/80 to inside:10.1.7.100/1221 duration 0:00:30 bytes 0 SYN Timeout
Packet Tracer says everything should work-
my-fw# packet-tracer input inside tcp 10.1.7.100 2345 1.1.1.177 80 detail
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Additional Information:
Forward Flow based lookup yields rule:
in  id=0xace546a8, priority=12, domain=capture, deny=false
        hits=773213, user_data=0xacf01938, cs_id=0x0, l3_type=0x0
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0000.0000.0000
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
in  id=0xab56e078, priority=1, domain=permit, deny=false
        hits=375991564, user_data=0x0, cs_id=0x0, l3_type=0x8
        dst mac=0000.0000.0000, mask=0100.0000.0000
Phase: 3
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
static (outside,inside) 1.1.1.177 10.1.3.77 netmask 255.255.255.255
  match ip outside host 10.1.3.77 inside any
    static translation to 1.1.1.177
    translate_hits = 0, untranslate_hits = 141
NAT divert to egress interface outside
Untranslate 1.1.1.177/0 to 10.1.3.77/0 using netmask 255.255.255.255
Phase: 4
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.1.0.0        255.255.0.0     inside
Phase: 5
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group inside_access in interface inside
access-list inside_access extended permit ip any any
in  id=0xab8d6900, priority=12, domain=permit, deny=false
        hits=1965550, user_data=0xa8b144c0, cs_id=0x0, flags=0x0, protocol=0
        src ip=0.0.0.0, mask=0.0.0.0, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Phase: 6
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
class-map class-default
match any
policy-map global_policy
class class-default
  set connection decrement-ttl
service-policy global_policy global
in  id=0xab8b3000, priority=7, domain=conn-set, deny=false
        hits=1992234, user_data=0xacbc9750, cs_id=0x0, flags=0x0, protocol=0
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0xab56ebc0, priority=0, domain=inspect-ip-options, deny=true
        hits=3020755, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 8
Type:
Subtype:
Result: ALLOW
Config:
in  id=0xacf23650, priority=17, domain=flow-export, deny=false
        hits=1152312, user_data=0xad004220, cs_id=0x0, flags=0x0, protocol=0
Phase: 9
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
static (inside,dmz) 10.1.0.0 10.1.0.0 netmask 255.255.0.0
  match ip inside 10.1.0.0 255.255.0.0 dmz any
    static translation to 10.1.0.0
    translate_hits = 17798, untranslate_hits = 77556
in  id=0xace4f290, priority=5, domain=host, deny=false
        hits=2923798, user_data=0xacf40cf8, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip=10.1.0.0, mask=255.255.0.0, port=0
Phase: 10
Type: NAT
Subtype:
Result: ALLOW
Config:
nat (inside) 1 0.0.0.0 0.0.0.0
  match ip inside any outside any
    dynamic translation to pool 1 (1.1.1.254 [Interface PAT])
    translate_hits = 1882494, untranslate_hits = 193619
Dynamic translate 10.1.7.100/2345 to 1.1.1.254/41106 using netmask 255.255.255.255
in  id=0xab9763b0, priority=1, domain=nat, deny=false
        hits=1883739, user_data=0xab9762f0, cs_id=0x0, flags=0x0, protocol=0
Phase: 11
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
out id=0xace38270, priority=5, domain=nat-reverse, deny=false
        hits=140, user_data=0xad0236f8, cs_id=0x0, flags=0x0, protocol=0
        dst ip=10.1.3.77, mask=255.255.255.255, port=0, dscp=0x0
Phase: 12
Type: NAT
Result: ALLOW
Config:
Reverse Flow based lookup yields rule:
in  id=0xad001480, priority=5, domain=host, deny=false
        hits=168, user_data=0xad0236f8, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip=10.1.3.77, mask=255.255.255.255, port=0
Phase: 13
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0xab96b448, priority=0, domain=inspect-ip-options, deny=true
        hits=3183895, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 14
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 3343232, packet dispatched to next module
Module information for forward flow ...
snp_fp_tracer_drop
snp_fp_inspect_ip_options
snp_fp_tcp_normalizer
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Module information for reverse flow ...
snp_fp_tracer_drop
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
Any ideas? Thanks.
Correct Answer by sudbose about 5 years 1 month ago
Please add the following commands to make it work:
# nat (inside) 1 0 0
# global (inside) 1 interface
# static (inside,inside) 1.1.1.177 10.1.3.77
# same-security-traffic permit intra-interface
/ Sudeep
Overall Rating: 5 (1 ratings)
Correct Answer
sudbose Wed, 02/29/2012 - 09:34
/ Sudeep
Collin Clark Wed, 02/29/2012 - 11:13
Same results after making the above changes. Packet Tracer now shows
Phase: 9
Type: NAT
Subtype:
Result: DROP
Config:
  match ip inside any inside any
    dynamic translation to pool 1 (No matching global)
    translate_hits = 5, untranslate_hits = 0
in  id=0xacf3d288, priority=1, domain=nat, deny=false
        hits=75, user_data=0xacf50698, cs_id=0x0, flags=0x0, protocol=0
haivrajesh Wed, 02/29/2012 - 13:10
please enable dns re write then it will work
Rajeswar
Collin Clark Wed, 02/29/2012 - 13:19
The application uses the IP address and not a hostname.
Maykol Rojas Wed, 02/29/2012 - 22:19
  • Cisco Employee,
  • Participante Destacado,
    Mejor Publicación, Diciembre del 2015
From the top of my head, if you remember, statics do routing first than the routing table itself.... Check on this static:
Phase: 9
Type: NAT
Result: ALLOW
Config:
Thats something that you should fix, however NOT the problem perse.
Based on what you are saying clients and server are internal which are on the range of 10.1.7.0/24 and the server is 10.1.3.77. So why are we seeing and outside connection being build?
Basically because of the same reason I highlited the Phase 9 of the packet tracer. Even thou you have a route statement that says every 10 network should be routed to the inside, this static
Is saying that 10.1.3.77 (based on the real interface which you claimed to be the outside). Now, it is really true that if you dont come out with some sort of static, this wont work properly because of two things
1-The dynamic nat which is taking 0 0 will need and will actually turn on nat control for a matter of speaking on the ASA, meaning everything will need to be translated
2-And second, but not less important, the firewall needs to route the packet and do the proper translation to send the packet when it is going back to the inside for someone asking for the public IP.
Now that being said and just to leave the theorical part aside remove the static as sundeep told you.
First of all, remove this
From this point and forth you have two options depending on your needs.
1- If you need your clients on the far network (the one that is behind the layer 3 device, not sure it it is the 10.1.3 or the 10.1.7) anyhow, if you need that far end network NOT to do connections to the direcltly connected one, you can just add one command to the commands already given by sundeep, it would be just a global inside in order to avoid asymetric routing
Global (inside) 1 interface
You can give it a try, but it will definetly break something else.
2-The second option you have is just to use TCP state bypass for the two networks. The main issue you are facing right now is asymetric routing, so by just putting two self translations, leaving that static as it is, removing proxyarp on the inside, that will do the trick and will allow you back and forth connectivity between the two networks: Here is the config
sysopt noproxyarp inside
static (inside,inside) 10.1.3.0 10.1.3.0
static (inside,inside) 10.1.7.0 10.1.7.0
access-list tcp_bypass permit tcp 10.1.3.0 255.255.255.0 10.1.7.0 255.255.255.0
access-list tcp_bypass permit tcp 10.1.7.0 255.255.255.0 10.1.3.0 255.255.255.0
class-map tcp_bypass
match access-list tcp_bypass
class tcp_bypass
  set connection advanced-options tcp-state-bypass
From the top of my head, giving those two different networks you have there you have something like this:
10.1.3.0----l3_Device-----10.1.7.0------ASA-----Internet
That being said, when the host 10.1.7.100 tries to initiate a connection to the server, it will go to the ASA (SYN), then the reply (SYN-ACK) will go directly to the 10.1.7.100 host, as the l3 device sees the 10.1.7.0 direclty connected and will send the packet directly to the host who tried to initiate the connection, the ASA on the other hand never saw that SYN-ACK packet, which will make the state table incomplete forcing the Firewall to drop the packet and never completing the 3 way handshake and the connection will timeout with a SYN timeout on the system log message. No matter what it is, if the server is the one directly connected or if it is the client that is directly connected, potato potato....
If you have any questions, feel free to throw them out.
Mike Rojas.
Collin Clark Thu, 03/01/2012 - 06:41
Thanks for your time Mike. The fix was adding Global (inside) 1 interface suggested by Sudeep.
sudbose Thu, 03/01/2012 - 07:00
Hi Colin,
Great to see that it is working fine. Still, I would recommend that you remove the following static as it is incorrectly defined.
# static (outside,inside) 1.1.1.177 10.1.3.77 netmask 255.255.255.255
Let us know if you have any questions regarding same.
/Sudeep
