02-28-2012 09:37 PM - edited 03-07-2019 05:15 AM
All the other switches / routers on quering for SNMP sysName.0 returns their FQDN in our network. The Nexus 7010 and 5020 switches in the network return only their name. "hostname xx" and "ip domain-name xx" defined on all the devices. The SNMP MIB is matching. There are no other SNMP related issues. How can I get the FQDN for these devices ?
$ snmpget -v 2c -c public m-65k-00.core sysName.0
SNMPv2-MIB::sysName.0 = STRING: m-65k-00.core.abcd.com
$ snmpget -v 2c -c public m-N7K-00.core sysName.0
SNMPv2-MIB::sysName.0 = STRING: m-N7K-00
$ snmpget -v 2c -c public m-N7K-00.core.abcd.com sysName.0
Rashid.
Solved! Go to Solution.
03-02-2012 12:01 AM
Hi Rashid,
Forgot to mention something, this object is context-aware, if for example your SNMP requests arrive on the mgmt0 interface it's necessary to configure the domain-name under the VRF not just globally, eg:
vrf context management
ip domain-name lab.cisco.com
I checked the versions you mentioned in my lab and see the expected behaviour (sysName contains FQDN) when the above config is in place.
Kind Regards,
/Phil
03-01-2012 01:10 AM
03-01-2012 11:26 PM
Thanks Phil, That was really helpful. Seems the problem might not be fixed in (or re-appeared) in later releases. We are facing the issue both in N7K and N5K. They N7K in particular is running a later version than the earlier fixed version according to the bug page.
N7010# show version
Software
BIOS: version 3.22.0
kickstart: version 5.2(3a)
system: version 5.2(3a)
BIOS compile time: 02/20/10
kickstart image file is: bootflash:///n7000-s1-kickstart.5.2.3a.bin
kickstart compile time: 12/25/2020 12:00:00 [12/16/2011 14:04:59]
system image file is: bootflash:///n7000-s1-dk9.5.2.3a.bin
system compile time: 12/15/2011 12:00:00 [12/16/2011 15:15:48]
N5020# show version
Software
BIOS: version 1.3.0
loader: version N/A
kickstart: version 5.0(3)N2(2a)
system: version 5.0(3)N2(2a)
power-seq: Module 1: version v1.2
BIOS compile time: 09/08/09
kickstart image file is: bootflash:///n5000-uk9-kickstart.5.0.3.N2.2a.bin
kickstart compile time: 10/15/2011 9:00:00 [10/16/2011 03:44:53]
system image file is: bootflash:/n5000-uk9.5.0.3.N2.2a.bin
system compile time: 10/15/2011 9:00:00 [10/16/2011 05:35:57]
03-02-2012 12:01 AM
Hi Rashid,
Kind Regards,
/Phil
03-04-2012 12:03 AM
Hi Phillip,
That did the trick. Its working returing FQDN now.
Thanks for your time.
Regards, Rashid.
