Warning message
syslogs
Feb 29th, 2012
I have got:
logging history informational
logging facility daemon
logging 192.168.12.15
and
snmp-server enable traps syslog
on my switches on the network.  I am getting clear text traps ok to the snmpc server under the history TAB but want the syslog information displayed on the CURRENT alarms tab.
Any ideas what i need to change to get the syslogs to appear on the screen.
regards
Kevin
cadet alain Wed, 02/29/2012 - 10:19
  • Purple, 4500 points or more
this seems more like a syslog server config, ain't it unless I misunderstood your query and you want the logging on your console device?
Regards.
Alain
ohareka70 Thu, 03/01/2012 - 05:38
Alain,
Its a syslog server called snmpc from www.Castlerock.com
We can see alarms and telnet / ssh into our routers and switches on the network after we setup the devices on site.
I think i was getting too many traps using #logging traps informational
so i am trying it with #logging traps warnings
If you look at the attachment on first email, i might also have too many snmp-server enable traps enabled so i will have to review these also.
regards,
Kevin
ohareka70 Fri, 03/02/2012 - 05:57
Any ideas how i can keep my syslog traffic but get rid of the switch port link up / down messages show below?
Info     02/03/2012 13:51:50 COMSW03                     Interface FastEthernet0/1, 1Link Down Trap
Info     02/03/2012 13:51:51 COMSW03                     COMSW03 UPDOWN - Interface FastEthernet0/1, changed state to down LINK error
Info     02/03/2012 13:51:53 COMSW03                     COMSW03 UPDOWN - Interface FastEthernet0/1, changed state to up LINK error
Info     02/03/2012 13:51:54 COMSW03                     Interface FastEthernet0/1, 1 Link Up Trap
thanks
Kevin
davy.timmermans Fri, 03/02/2012 - 06:54
  • Silver, 250 points or more
You can try if the switch accept the following interface command
interface fas0/1
no logging event link-status
for a range of ports (eg all ports from 1 till 24)
interface range fas0/1 - 24
