Warning message
ACS Command line login..
Answered Question
Feb 29th, 2012
I have a superadmin account in ACS.
with this account i can able to login GUI but can't able to login CLI mode.
what could be the problem ?
Correct Answer by Eduardo Aliaga about 5 years 5 months ago
You've already created a CLI admin account during the first setup of ISE. If you forgot the CLI admin password you can perform "password recovery" by booting from ISE DVD and choosing option 3 or 4.
Correct Answer by camejia about 5 years 5 months ago
Hello Tony,
The ACS GUI Administrator accounts and CLI Administrator accounts are different. You cannot login with GUI accounts into CLI.
You need to use CLI created accounts to access the ACS command line. You should have created one when first installing the ACS 5.x.
If this was helpful please rate.
Overall Rating: 5 (2 ratings)
Correct Answer
camejia Fri, 03/02/2012 - 14:19
  • Silver, 250 points or more
Hello Tony,
tonythacheth Sat, 03/03/2012 - 05:58
Hi Carlos Mejia,
Thanks for your mail,
now i have only GUI access. with can i able to create an account for the CLI access ??
i mean what would i do to get a new CLI access user account.
Correct Answer
Eduardo Aliaga Sun, 03/04/2012 - 14:59
