Second dialtone
yixiu0317
We are having problem with the second dialtone in CUCM 7
When user dial the forth digit of the number, he hears the second dialtone
For example, if he want to dial external number, he dial 081234567, he will hear the first dial tone after he dial 0, then after he dial 2, he will hear the second dial tone, if he keeps dialing the rest of the number, the call still can go through.
If I untick the "Provide Outside Dial Tone" option for the route pattern, it can fix the problem but user will not hear the dial tone when they dial 0
The other route patterns have no problem at all, only this particular pattern has problem
Any suggestion for this problem?
Jaime Valencia
The secondary dial tone is provided when all the possible matches in the digit analysis have the checkbox for the secondary dial tone, if you hear it until the 4th digit that means that you're matching something that either doesn't have it checked or simply doesn't have the option.
Look at your dial plan and see what else you're matching on those first 4 digits.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
yixiu0317
Thank you for your prompt response.
I found a route pattern similiar to the one we had problem and it did not have the option ticked, after I ticked the option, it worked. but could you take a little bit time to explain to me something that I am confused
for example I have 2 route pattern 0.[7-9]XXXXXXX(option ticked) and 0.826XXXXX(option not ticked), the number l want to dial is  082012345, as my understanding after I dialed 2 I should hear the second dial tone, but why after dialed 0 I heard the dial tone
Thank you in advance
yixiu0317
Hi         Java
I found the reason
