Allow Multiple subnets
Mar 1st, 2012
Good morning I hope someone can shed some light on the following problem.   I have 2 subnets both on seperate vlans - 1(static) and 100(dhcp).  I have the lwapp ap's set to receive a vlan 100 DHCP ip address from our server.  The switchport is trunked with a native vlan 100, this allows users to receive a vlan100 dhcp address. The problem is the users utilizing vlan 1 which is a static subnet are not allowed access through the access-point.  They can associate to the AP with no problem, but unable to past traffic.
Larnel
Stephen Rodriguez Thu, 03/01/2012 - 07:04
  • Purple, 4500 points or more
Larnel,
     To clarify, do the users have to be in VLAN 1 to gain access to those resources?
Can you post the AP config?
Steve
larnelhight Thu, 03/01/2012 - 07:30
Yes, but only a select few.  Everyone else is on vlan 100 which works perfectly.
The AP's are LWAPP so not real config on the ap itself.  Hreap Vlan is enabled on vlan 1.  The WLANS associated with the ap are vlan 1 as well.
Stephen Rodriguez Thu, 03/01/2012 - 07:33
ok, so the problem is that users in VLAN 100 can't access the resources in VLAN 1.  Is that correct?  If not, please give me a detailed description of the issue.
Steve
larnelhight Thu, 03/01/2012 - 07:45
no, the users in vlan 1 cannot access the internet.  They can associate with the access-point, but the AP is not passing the traffic through.  If they are wired we have no problems.
switchport config
interface GigabitEthernet0/35
description "APe8b7.48f5.1b21 - G0"
switchport trunk native vlan 100
switchport mode trunk
srr-queue bandwidth share 10 10 60 20
queue-set 2
priority-queue out
mls qos trust dscp
auto qos voip trust
spanning-tree portfast trunk
Stephen Rodriguez Thu, 03/01/2012 - 07:48
ok, can you share the AP config?  more than likely you need to create another SSID and map it to VLAN 1, with the sub-interfaces created.
Steve
larnelhight Thu, 03/01/2012 - 07:53
version 12.4
no service pad
service password-encryption
logging rate-limit console 9
aaa new-model
aaa authentication login default local
aaa authentication login reap_eap_methods group radius
aaa session-id common
eap profile lwapp_eap_profile
method fast
interface Dot11Radio0
no ip route-cache
interface Dot11Radio0.1
encapsulation dot1Q 1
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 1
interface Dot11Radio0.17
encapsulation dot1Q 17 native
no ip route-cache
bridge-group 1
interface Dot11Radio1
no ip route-cache
interface Dot11Radio1.1
no ip route-cache
bridge-group 1
interface Dot11Radio1.2
no ip route-cache
bridge-group 1
interface Dot11Radio1.17
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.1
encapsulation dot1Q 1 native
ip address dhcp client-id GigabitEthernet0
no ip route-cache
bridge-group 1
no ip http server
radius-server local
  no authentication eapfast
  no authentication leap
  no authentication mac
  group hreap
control-plane
end
Stephen Rodriguez Thu, 03/01/2012 - 07:58
yeah, everything is mapping to VLAN 100.
Can you screenshot the HREAP VLAN mappings?
Stephen Rodriguez Thu, 03/01/2012 - 08:29
with what you have configured here, all the traffic would be untagged, and sent down to the switch, which would put it in VLAN 100.
Try changing the native to be 100.  that should change the bridge groups on the HREAP to be correct.
Steve
larnelhight Fri, 03/02/2012 - 07:37
So changing the native to vlan 100 will allow the AP to pass vlan 1 traffic?
Stephen Rodriguez Fri, 03/02/2012 - 07:47
I believe it will.  Currently, you are telling the AP that everything is flat, the native and all the SSID are linked to VLAN 1, which is why all of your bridge-groups show as bridge-group 1 in the AP config.
By changing the native to be VLAN 100, this will make the interface Dot11Radio1.17 be a different VLAN, so all the management traffic will be untagged, but any traffic that really should be in VLAN 1, will be tagged for VLAN 1.  Currently all of the traffic is being sent untagged and getting put into VLAN 100 on the switch.
Keep in mind, that if one of the WLAN should be in VLAN 100, you want to map it to VLAN 100, and not VLAN 1
Steve
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
