Sup 720 +IOS + netflow ?
Answered Question
Mar 1st, 2012
I am looking to enable netflow on our 6513E core switch. We run sup 720's IOS enabled.
Are there netflow limitations on the SUP card ? Essentially we have 2 buildings connected via fiber
and each floor is a vlan that is connected back to the 6513.
One interface on the 6513 is connected to the inside interface of our ASA and I would like to get netflow stats off that
L2 interface for internet traffic outbound. Is that possible ?
I would also like to pull netflow stats of each vlan L3 interface to give me top talkers etc from each floor. Is that also possible ?
Cheers
Dave
Correct Answer by glen.grant about 2 years 1 month ago
  You should be able to do what you are asking , refer to this page
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080721701.shtml
Average Rating: 5 (1 ratings)
Don Jacob Fri, 03/16/2012 - 09:47
That is the number of NetFlow entries (flow records) a device's cache  can hold. Each entry refers to an IP traffic conversation based on the  key fields.
There are 7 key fields:
1 and 2.Source and Destination IP Address
3 and 4. Source and Destionation port number
5. Layer 3 Protocol
6. Source ifindex
7. ToS
Each  IP traffic which is active has a flow record in the cache. The flow  record is created based on the key fields, ie. if all the key fields are  same and the flow is active, it is added to the same flow record and  then exported from the cache based on timeouts.
Don Thomas Jacob
www.netflowanalyzer.com
NOTE: Please rate posts and close questions if your query has been answered
Login or Register to take actions
Posted March 1, 2012 at 8:07 AM
Stats:
Replies:6 Avg. Rating:5
Views:331 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
Rank Username Points
1 14,997
2 8,150
3 7,725
4 7,083
5 6,727
175
84
75
59
55
