G722 Codec
Answered Question
Mar 1st, 2012
we just received 5 new 8945 phones and I want to use the G722 codec on them, the question is where can I get this from or does it come installed with CM already. And if it's already on CM where do I go to check and make it the default.
Correct Answer by Jaime Valencia about 5 years 3 weeks ago
You set wheter to advertise/use it at the service parameter level and device level.
G.722 Codec Enabled: Required Field This parameter determines whether Cisco Unified Communications  Manager allows G.722 negotiation for all, some, or no devices. Valid  values specify Enabled for All Devices, Enabled for All Devices Except  Recording-Enabled Devices, or Disabled.
   This is a required field.
   Default:                  Enabled for All Devices
On device: Advertise G.722 CodecRequired Field
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 03/01/2012 - 12:36
  • Cisco Employee,
  • Hall of Fame,
    2011
java
