VTP Domain Propagation
Answered Question
Mar 2nd, 2012
Hi All,
Let say I have two 48 ports switches, one vtp domain set as "site1.example.com", another vtp domain set as "site2.example.com".
Both switches has VLAN 201 to 248, assigned to port 1 to port 48.
VLAN 201 to VLAN 245 in switch 1 are assigned to Site1 Customers and VLAN 201 to VLAN 245 in switch 2 are assigned to Site 2 Customers, with different IP addresses.
Both switches has the same vtp password.
If I connect the two switches together via port 48, which is assigned to VLAN 248.
Question: Will VLAN informations (eg VLAN 201 to VLAN 245) in Switches 1 interfere with VLAN information in Switches 2 or vice versa?
Thanks you in advance for any help given.
Correct Answer by davy.timmermans about 5 years 1 month ago
the switch compares the VTP domain name to its own VTP domain name. If the name is different, the switch simply ignores the packet. Thus no interference.
PS. To exchange VTP packets, the link must be a trunk ;-)
In real life - VTP server/client is almost not used
Overall Rating: 5 (1 ratings)
Correct Answer
davy.timmermans Fri, 03/02/2012 - 06:49
  • Silver, 250 points or more
burleyman Fri, 03/02/2012 - 07:01
  • Blue, 1500 points or more
Davy,
All we use is VTP server/client, so it is used in the real world, and I know many other that use that setup as well. We have absolutely no issues at all and it works great. Why would you think it is not used?
Mike
davy.timmermans Fri, 03/02/2012 - 07:30
As you probably know - transparent mode is recommended. I said it's almost not used, and this via personal experience in several environments. In my opinion you've more control if you work in transparent mode + the known disadvantages of server/client.
burleyman Fri, 03/02/2012 - 07:46
I agree and I did read your post too fast and missed the almost
You do need to make sure you understand how VTP server/client works and you should be good.
Mike
fb_webuser Fri, 03/02/2012 - 07:22
Why are you using VTP in this case ?
If you have a switch and you want it to have its own private VLANS and not interfere with the VTP domain you can set
vtp mode passive
Then it won't advertise its VLANS
Posted by WebUser Stuart Gall
burleyman Fri, 03/02/2012 - 07:25
Also by having them in different VTP domains they do not interfere as Davy said earlier so it would not be an issue.
Mike
Related Content
