Configuration Changes logging issue, ASDM related?
Mar 2nd, 2012
I've run into an interesting problem.
ASA: 8.4(2)
ASDM: 6.4(5)
When I make a change at the CLI, syslog message ASA-5-111008 is generated and sent to the syslog servers, local buffer, and ASDM.
When I make a change in ASDM, syslog message ASA-5-111008 is  generated and sent to the local  buffer and ASDM. It is NOT sent to the syslog server.
Here's my logging config...
Firewall# sh run logging
logging enable
logging timestamp
logging standby
logging buffer-size 409600
logging buffered informational
logging trap notifications
logging asdm notifications
logging host Inside xx.xx.xx.AA 6/1468
logging host Inside xx.xx.xx.BB 6/1468
logging flash-minimum-free 10240
logging flash-maximum-allocation 10240
logging permit-hostdown
Surely I'm missing something obvious.  Is this a known bug?
Thanks!
Average Rating: 0 (0 ratings)
Marvin Rhoads Fri, 03/02/2012 - 12:25
Not sure about a bug - there is a very similar one open and documented in the ASA release notes - CSCtx16166
Note your ASDM version is a few back from the latest. I'd load up ASDM 6.4(7) just for grins and see if it behaves the same.
rrfield Fri, 03/02/2012 - 12:30
Ha, I did upgrade just a few minutes ago, but same result.
That does look similar, and so does ...
CSCth14248 ASA not sending all logging messages via TCP logging
Looks like I'll need to upgrade to 8.4(3) to fix these and see how it goes.
thanks!
Login or Register to take actions
Posted March 2, 2012 at 8:46 AM
Stats:
Replies:2 Avg. Rating:
Views:725 Votes:0
Shares:0
Related Content
Discussions Leaderboard
Rank Username Points
1 7,861
2 6,140
3 3,165
4 1,473
5 1,446
