ios aaa and telnet
Mar 2nd, 2012
I have aaa new model configured on a number of isr's(1800, 1900, 2900, 3800 etc).  When i have aaa configured, the telnet logins use that authentication and not the password in the line vty portion.  Is this by design.  would disabling aaa enable both telnet and aaa authentications, essentially making it a dual login.
Overall Rating: 5 (1 ratings)
John Blakley Fri, 03/02/2012 - 10:00
  • Purple, 4500 points or more
This is by design. AAA authentication takes precedence. You won't be able to get a default login because once you enable AAA, it immediately asks for a username to authenticate with.
cadet alain Fri, 03/02/2012 - 10:07
aaa authentication login default line  should give the default login with aaa enabled but not both as you said.
Regards.
Alain.
John Blakley Fri, 03/02/2012 - 10:12
Alain....rated. I've never used that one, but it works...
