Remote Access ASA to ASA VPN
Answered Question
Mar 2nd, 2012
This is my first post on this site. Hello to everyone!
I have not really set up ASAs nor VPNs on Cisco devices before. I'm currently attempting to configure a remote access VPN between ASA devices, a 5505 and a 5510. The 5510 is meant to be the server and the 5505 is meant to be the easyvpn client. The reason I am opting for remote access as opposed to site to site is that I have many 5505s at remote sites that I will need to configure in the future, and they will be moving around a bit (I would prefer not to have to keep up with the site-to-site configs). The 5510 will not be moving. Both ASA devices are able to ping out to 8.8.8.8 as well as ping each other's public facing IP.
Neither ASA can ping the other ASA's private IP (this part makes sense), and I am unable to SSH from a client on the 5510 side to the 5505's internal (192) interface. I am wondering if anyone more experienced in ASA remote VPNs than myself is able to see anything wrong with my configuration? I have pasted sterilized configs from both ASAs below.
Thanks very much for any assistance!
ASA 5510 (Server)
ASA Version 8.0(4)
hostname ASA5510
domain-name <domain>
enable password <password> encrypted
passwd <password> encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 48.110.3.220 255.255.255.192
interface Ethernet0/1
nameif inside
security-level 100
ip address 192.168.191.252 255.255.252.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit intra-interface
access-list NONAT_VPN extended permit ip 192.168.0.0 255.255.0.0 192.168.0.0 255.255.0.0
access-list VPN_REMOTE_IPS remark EZ VPN REMOTE IP RANGES
access-list VPN_REMOTE_IPS extended permit ip 192.168.0.0 255.255.0.0 192.168.0.0 255.255.0.0
pager lines 24
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-613.bin
no asdm history enable
arp timeout 14400
nat (inside) 0 access-list NONAT_VPN
route outside 0.0.0.0 0.0.0.0 48.110.3.193 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set TestVPN esp-aes-192 esp-sha-hmac
crypto ipsec security-association lifetime seconds 86400
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map DYNAMIC-MAP 5 set transform-set TestVPN
crypto dynamic-map DYNAMIC-MAP 5 set security-association lifetime seconds 86400
crypto dynamic-map DYNAMIC-MAP 5 set security-association lifetime kilobytes 4608000
crypto map outside_map 1 set security-association lifetime seconds 86400
crypto map outside_map 1 set security-association lifetime kilobytes 4608000
crypto map S2S-VPN 100 set security-association lifetime seconds 86400
crypto map S2S-VPN 100 set security-association lifetime kilobytes 4608000
crypto map OUTSIDE_MAP 65530 ipsec-isakmp dynamic DYNAMIC-MAP
crypto map OUTSIDE_MAP interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 1
ssh 192.168.0.0 255.255.0.0 inside
ssh timeout 15
console timeout 30
management-access inside
priority-queue outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
group-policy EZVPN_GP internal
group-policy EZVPN_GP attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value VPN_REMOTE_IPS
nem enable
username <sticks> password <SamplePassword> encrypted privilege 3
username <stones> password <SampleAdminPassword> encrypted privilege 15
tunnel-group EZVPN_TUNNEL type remote-access
tunnel-group EZVPN_TUNNEL general-attributes
default-group-policy EZVPN_GP
tunnel-group EZVPN_TUNNEL ipsec-attributes
pre-shared-key <VPNPassword>
class-map inspection_default
match default-inspection-traffic
class-map VOICE-CLASS
match dscp ef
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map PRIORITY_POLICY
class VOICE-CLASS
priority
policy-map QOS-TRAFFIC-OUT
class class-default
shape average 154088000
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect icmp
service-policy global_policy global
prompt hostname context
Cryptochecksum:10156ad7ab988ae7ed66c4b6d0b4712e
: end
ASA 5505 (Client)
ASA Version 8.2(5)
hostname ASA5505
names
switchport access vlan 2
shutdown
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
interface Vlan1
nameif inside
security-level 100
ip address 192.168.19.1 255.255.255.192
interface Vlan2
nameif outside
security-level 0
ip address 174.161.76.217 255.255.255.248
ftp mode passive
pager lines 24
mtu inside 1500
mtu outside 1500
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 174.161.76.222 1
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
http server enable
crypto ipsec security-association lifetime seconds 28800
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
telnet timeout 5
ssh 48.110.3.220 255.255.255.255 outside
ssh timeout 5
console timeout 0
vpnclient server 48.110.3.220
vpnclient mode network-extension-mode
vpnclient vpngroup EZVPN_TUNNEL password <VPNPassword>
vpnclient username <sticks> password <SamplePassword>
webvpn
parameters
message-length maximum client auto
inspect ftp
inspect h323 h225
inspect h323 ras
inspect ip-options
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
no call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http
https://tools.cisco.com/its/service/odd ... DCEService
destination address email
[email protected]
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:bd465cea07c060a409a2eade03b487dc
: end
Correct Answer by rizwanr74 about 5 years 5 months ago
Please follow this link to create Dynamic Remote L2L tunnel Server on ASA5510.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807ea936.shtml
Here is a link for you to create Site to Site vpn tunnel and this tunnel can be client to above Dynamic L2L tunnel Server.
http://www.cisco.com/en/US/products/ps5855/products_configuration_example09186a0080a9a7a3.shtml
Hope that helps.
If you have a question, please ask.
thanks
Rizwan Rafeek
Overall Rating: 5 (1 ratings)
riddle721 Fri, 03/02/2012 - 15:44
A guy on another forum spotted an oversight of mine. I never enabled vpnclient on the 5505. So, consider this answered!
Correct Answer
rizwanr74 Fri, 03/02/2012 - 16:29
  • Gold, 750 points or more
Hope that helps.
thanks
Rizwan Rafeek
Pinesh Amin Sat, 03/03/2012 - 14:37
Rizwan,
I apologize..i have deleted my post.  Thank you for your help..
Related Content
