nexus1010 connectivity options change
davidcheung
Hi All,nexus1010 has 4 connectivity options. my questions is:
if we initially deploy option 1 for paired 1010 and 1000v switch has been built, are we able to change to other option e.g. option 3 later whithout requesting 1000v rebuild?  Best REGARDS
mwronkow
Hello David,
Yes, the Nexus 1010 'network-uplink type' may be altered after VSBs are installed.  After the configuration change is completed both N1010s must be reloaded at the same time.  The control/packet/data vlans will automatically re-pin to the designated NIC ports.
FYI - In SP1(4) a new Flexible Networking option allows additional topologies.
Matthew
mwronkow
Hello David,
Matthew
Thank u very much!!!
