2610 No Internet Access...
jwood1650
I have a Cisoc 2610 connected to my network, 1 Ethernet port and a WIC-2T card.  I have ther serial connection to the main router and the ethernet going to the switch. I can ping all device throught the network...but the 2610 can't ping any outside address (no internet connection).  I have the internet connection going through my 3745 (which the 2610 is connected to via serial cable).  I put a default route into the 2610 but still no luck...please help...
Here are the running configs:
2610:
version 12.3
service timestamps debug uptime
service timestamps log uptime
hostname Router
boot-start-marker
boot system flash
boot-end-marker
no logging on
no aaa new-model
ip subnet-zero
ip cef
ip dhcp pool 192.168.3.1
   default-router 192.168.3.1
   dns-server 192.168.2.127 192.168.2.128 8.8.8.8
username woodjl1650 privilege 15 password 0 henry999
interface Ethernet0/0
ip address 192.168.3.1 255.255.255.0
full-duplex
interface Serial0/0
ip address 10.0.1.10 255.255.255.252
clock rate 2000000
interface Serial0/1
no ip address
shutdown
router eigrp 1
network 10.0.0.0
network 192.168.3.0
no auto-summary
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0
snmp-server community public RO
snmp-server community private RW
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
end
3745:
version 12.4
hostname 3745-Internet
boot-start-marker
boot system flash:
boot-end-marker
no logging buffered
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
memory-size iomem 25
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.2.1 192.168.2.150
ip dhcp pool HOME-Network
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   dns-server 8.8.8.8 8.8.4.4 192.168.2.127 192.168.2.128
ip domain name www.jkkcc.com
ip name-server 192.168.2.127
parameter-map type regex sdm-regex-nonascii
pattern [^\x00-\x80]
archive
log config
  hidekeys
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address dhcp
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface Serial0/0
description $FW_INSIDE$
ip address 10.0.1.9 255.255.255.252
interface FastEthernet0/1
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip route-cache flow
duplex auto
speed auto
interface Serial0/1
ip address 10.0.1.5 255.255.255.252
clock rate 2000000
router eigrp 1
network 10.0.0.0
network 192.168.0.0
network 192.168.2.0
no auto-summary
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 15 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.2.128 80 interface FastEthernet0/0 80
ip nat inside source static tcp 192.168.2.128 25 interface FastEthernet0/0 25
access-list 15 permit 192.168.2.0 0.0.0.255
snmp-server enable traps tty
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
webvpn cef
end
Add the default route on the 3745 router:
3745-Internet(config)# ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
And add:
access-list 15 permit 192.168.3.0 0.0.0.255
access-list 15 permit 10.0.1.4 0.0.0.3 (if you want the 2610 router itself to reach the internet)
11 Replies 11
pjmonline
Looks like the 3745 has no ip route statement for the ip subnet on the 2610. Add that and see what you get. You may also have to add a ip nat statement for that subnet as well.
Sorry still kinda learning, what would that statement look like?
viswamin
From the config it looks like the L3 switch 3745 is performing the NAT.
The outside interface is fa0/0 which obtains an IP address from the pool configured on the switch or on the router...which could be either 192.168.2.X or 192.168.3.X.
Both these addresses are in the private range so i dont think that can be used to route the traffic to the internet. are you performing natting somewhere outside?
-Vijay
Yes the 3745 is getting the IP address from the ISP on the FE0/0 port.  FE0/1 is connected to my switch and all PC's on that switch have internet access (from the 192.168.2.0 network).  I have a 2610 connected via serial from the 3745 which I have one PC and 5 IP camera connected to... I can ping all devices, but can't access the internet from the 2610 router...No other NATTING is configured except for the 3745...
if I'm not wrong, since 2610 is connected to 3745 via serial I would hope that the serial interface should also have to be configured as "ip nat inside" since the PC's attached to the router would be having an ip on the private range.
-Vijay
No the 2610 serial interface does not have NAT....I just added the ip nat inside on the serial interface, do I need to do it for the ethernet one as well?  Should that solve the problem?
Sorry I wasn't clear..
I meant the Serial interface of the Switch should be configured with "ip nat inside" so that the traffic coming on this interface (typically I would assume it should be also be in private range) would also have to get natted .
I'm still a beginner. so I would let experts to confirm.
-Vijay
I dont have a serial interface on my switch, just the routers....
Alright this is what I have now:
and still no internet access on the 2610...
2610
version 12.3
hostname Router
boot-start-marker
boot system flash
boot-end-marker
no logging on
no aaa new-model
ip subnet-zero
ip cef
full-duplex
interface Serial0/0
clock rate 2000000
interface Serial0/1
no ip address
shutdown
router eigrp 1
network 10.0.0.0
network 192.168.3.0
no auto-summary
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.1.9
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
end
3745
version 12.4
boot-start-marker
boot system flash:
boot-end-marker
no logging buffered
aaa new-model
ip cef
archive
log config
  hidekeys
ip address dhcp
ip nat outside
ip route-cache flow
duplex auto
speed auto
interface Serial0/0
ip nat inside
ip nat inside
ip route-cache flow
duplex auto
speed auto
interface Serial0/1
ip nat inside
clock rate 2000000
router eigrp 1
network 10.0.0.0
network 192.168.0.0
network 192.168.2.0
no auto-summary
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
webvpn cef
end
And add:
The access list worked....the default route did not, killed the internet access all together.....but everything is working now...thanks.
