Warning message
IP helper-address not working in different segment vlans
Answered Question
Mar 3rd, 2012
The dhcp server is located in vlan 100 and only vlan 100 is able to get the DHCP IP from it. The rest of the vlans are not getting DHCP request. Also, the network is getting intermittent disconnect after a Virtual Environment equipment started to have problems and the ports that they are using are trunking ports. The trunking ports has been disabled but the DHCP is still not working for additional vlans.
Service dhcp is enabled.
Thanks!
Correct Answer by Richard Burts about 5 years 5 months ago
Maria
Thank you for posting back to the forum indicating that the problem was solved and how you fixed it. VTP pruning was certainly not one of the things that I had thought about as a possible cause of this and it is interesting that this turned out to be the problem. Now that you have it working perhaps you want to mark this question as resolved?
Rick
Overall Rating: 5 (1 ratings)
Reza Sharifi Sat, 03/03/2012 - 09:45
  • Cisco Designated VIP,
    2017 LAN
Please post your config (sh run).
Richard Burts Sat, 03/03/2012 - 09:57
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Maria
I agree with Reza that we do not have enough information yet to be able to give you good answers. In addition to posting the configuration I would ask that you specify what is the address of the DHCP server. We also need to know whether DHCP has worked in the past and stopped working or is it the case that DHCP has not ever worked on the other segment VLANs.
Rick
maria.melendez Sat, 03/03/2012 - 12:01
Here's the config ...  This is a catalyst 3750. Yes DHCP was working before properly. Yesterday stopped working, server has been rebooted and although the ip helper-address is not in vlan 100 is the only one working. I'll appreciate any information, thanks!
version 12.2
no service pad
service tcp-keepalives-in
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname router
boot-start-marker
boot-end-marker
logging console critical
enable secret 5 $1$fE0f$2YuK88Rj3xzIOnVg2kKjM.
username maria privilege 15 secret 5 $1$Q6RM$AMj5ByYAbaOi9nCWEW6No/
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login VTY group tacacs+ local
aaa authorization exec default local
aaa authorization network default local
aaa session-id common
clock timezone EST -5
clock summer-time EDT recurring
switch 1 provision ws-c3750-48ts
system mtu routing 1500
vtp interface g1/0/2
ip subnet-zero
no ip source-route
ip routing
no ip gratuitous-arps
no ip domain-lookup
ip domain-name abc.com
ip name-server 123.123.123.123
password encryption aes
crypto pki trustpoint TP-self-signed-13602432...rsakeypair TP-self-signed-13602432
crypto pki certificate chain TP-self-signed-13602432
certificate self-signed 01  ...
  DFA50ED8 9FE8F40F 3CD0F1DA
  B1D3823C DEE290AC C9D95DFF C8DF
  quit
errdisable recovery cause security-violation
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
spanning-tree uplinkfast
vlan internal allocation policy ascending
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh version 2
interface Loopback0
ip address 10.10.10.10 255.255.255.255
interface FastEthernet1/0/1
switchport access vlan 6
switchport mode access
interface FastEthernet1/0/2
switchport access vlan 140
shutdown
interface FastEthernet1/0/47
shutdown
interface FastEthernet1/0/48
switchport access vlan 4
shutdown
no mdix auto
interface GigabitEthernet1/0/1
no switchport
ip address A.B.1.252 255.255.255.0
ip access-group border_in in
ip access-group border_out out
flowcontrol receive on
interface GigabitEthernet1/0/2
switchport mode trunk
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface Vlan1
shutdown
interface Vlan2
ip address A.B.2.254 255.255.255.0
interface Vlan4
ip address A.B.4.254 255.255.255.0
ip helper-address A.B.100.200
interface Vlan5
ip address A.B.5.254 255.255.255.0
interface Vlan6
ip address A.B.6.254 255.255.255.0
interface Vlan7
ip address A.B.7.254 255.255.255.0
interface Vlan13
interface Vlan100
ip address A.B.100.254 255.255.255.0
interface Vlan111
ip address A.B.111.254 255.255.255.0
ip default-gateway A.B.111.254
no ip classless
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
ip route 0.0.0.0 0.0.0.0 A.B.1.254
ip http server
ip http authentication local
ip http secure-server
ip access-list extended border_in
permit tcp host A.B.1.111 any
permit udp host A.B.1.111 any
permit tcp C.D.0.0 0.0.255.255 A.B.0.0 0.0.255.255 eq www
permit tcp C.D.0.0 0.0.255.255 A.B.0.0 0.0.255.255 eq 443
permit tcp C.D.0.0 0.0.255.255 A.B.0.0 0.0.255.255 eq 2222
deny   tcp any A.B.0.0 0.0.255.255 eq 1 log
deny   tcp any A.B.0.0 0.0.255.255 eq 47017 log
deny   tcp any A.B.0.0 0.0.255.255 range 6711 6712 log
deny   tcp any A.B.0.0 0.0.255.255 eq 6776 log
deny   tcp any A.B.0.0 0.0.255.255 eq 6669 log
deny   tcp any A.B.0.0 0.0.255.255 eq 2222 log
deny   tcp any A.B.0.0 0.0.255.255 eq 7000 log
permit ip any any
ip access-list extended border_out
deny   tcp A.B.0.0 0.0.255.255 any eq 1 log
deny   udp A.B.0.0 0.0.255.255 any eq 1 log
deny   tcp A.B.0.0 0.0.255.255 any eq echo log
deny   udp A.B.0.0 0.0.255.255 any eq echo log
deny   tcp A.B.0.0 0.0.255.255 any eq discard log
deny   udp A.B.0.0 0.0.255.255 any eq snmp log
deny   tcp A.B.0.0 0.0.255.255 any eq 162 log
deny   udp A.B.0.0 0.0.255.255 any eq snmptrap log
deny   udp A.B.0.0 0.0.255.255 any eq xdmcp log
permit tcp host A.B.101.175 C.D.0.0 0.0.255.255
permit udp host A.B.101.175 C.D.0.0 0.0.255.255
permit ip any any
logging history informational
logging source-interface Loopback0
logging A.B.2.231
snmp-server host A.B.2.230 seclee
snmp-server host A.B.2.231 seclee
tacacs-server host A.B.2.229
tacacs-server directed-request
line con 0
session-timeout 10
line vty 0 4
exec-timeout 5 0
login authentication VTY
transport input ssh
line vty 5 15
exec-timeout 5 0
transport input ssh
end
Reza Sharifi Sat, 03/03/2012 - 12:46
    2017 LAN
Can the DHCP server ping A.B.100.254?
Can the DHCP server ping any other vlan's interface?
can you ping the DHCP IP from the switch?
this is the interface of vlan 111 and should not be use as a default gateway.  Default gateway needs to be the next hop IP address and not local SVI's IP address.  Since you already have default route in your config, default-gateway should
be deleted.
maria.melendez Sat, 03/03/2012 - 13:09
Can the DHCP server ping A.B.100.254?  YES
Can the DHCP server ping any other vlan's interface? YES
can you ping the DHCP IP from the switch? YES but only from the router, not the additional switches.
Ok, thanks for the help!!
Richard Burts Sat, 03/03/2012 - 14:57
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Maria
The configuration that you posted shows several VLANs that do not have ip helper-address configured (VLANs 2, 7, and 111). If this is an accurate copy of the config then those VLANs would not be able to get address assignments from the DHCP server.
I  am interested in your statement that :"can you ping the DHCP IP from  the switch? YES but only from the router, not the additional switches"  This makes me wonder if perhaps the default gateway on the server  changed. If you were to take one of the PCs on a VLAN (perhaps vlan 4 or 5) and configure it with a static IP in the appropriate subnet, then would it be able to ping the DHCP server.
Rick
maria.melendez Sat, 03/03/2012 - 15:35
Richard,
Yes, this config is accurate and only VLAN 4, 5, 6, are using the ip helper-address and are supposed to get the DHCP IP addresses. We have machines using static ips ( in vlan 5 and 6) and we can ping the DHCP server. But because other machines are trying to get IPs from DHCP, the network is dropping packets.
Sorry for the confusion, I have a main router and 3 additional switches(Catalyst 4506) connected in different floors. Forget about my comment, I'm not going to be able to ping from the switches any device other than my network machines, this is not permitted by ACL.
acampbell Sat, 03/03/2012 - 17:52
  • Green, 3000 points or more
Maria,
Are the scopes on the DHCP server configured under a SUPERSCOPE.
If they are you need to remove/delete the SUPERSCOPE, just leave each scope as an
independant entity.
Alex
maria.melendez Sat, 03/03/2012 - 21:13
Acampbell,
Not sure if I understand right the superscope concept.  Can you explain it ?  I'm not the DHCP server administrator. We have all the VLan scopes defined in our DHCP server A.B.100.200.
Thanks!
acampbell Sun, 03/04/2012 - 05:00
Maria,
You need to ask yor DHCP server administrator if they have set up the scope that you reequire under
a SUPERSCOPE.
SUPERSCOPE--MARIAS-VLANS
-MARIA SCOPE 1 VLAN-A
-MARIA SCOPE 2 VLAN-B
-MARIA SCOPE 3 VLAN-C
----etc
SUPERSCOPES are not compatable with the type of working you need.
They are used to supply Muliple IP Subnets to a single broadcast domain.
You ar using 1 SUBNET per VLAN (Broadcast domain) each of your scopes to be individual.NO SUPERSCOPE
----etc
May be helpful
Alex
Richard Burts Sun, 03/04/2012 - 14:06
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Alex
In a previous post in this thread Maria says that the DHCP server was working and then stopped working. From that I believe that we can deduce that the issue is not superscope.
Maria
If PCs in VLANs 5 and 6 with static addresses can ping the DHCP server then this demonstrates that the problem is not basic IP connectivity to the DHCP server and is not a problem with the default gateway of the DHCP server (both of which were on my list of possible problems).
I do not see any obvious problems in the configuration, and we know that there is IP connectivity, so we need to look for something else that causes the problem. Perhaps you can check with the administrator of the DHCP server and ask if there are any issues on the server or if any changes have been made recently.
Would it be possible to set up a packet capture to examine traffic being sent to the DHCP server?
Rick
maria.melendez Sun, 03/04/2012 - 14:34
Richard,
Yes, you are correct everything was working properly before ... Machines on vlan 5 and 6 using static IPs can ping the DHCP server.
I know that the missing part here is the DHCP server, but we cant get a hold of the admin. Let me remove any sensitive info from the packet capture that I have from wireshark and I'll post that soon.
Thanks all for your suggestions!!
-M
maria.melendez Sun, 03/04/2012 - 15:09
Here's from workstation in vlan 6 asking for IP, the correct IP for this machine is A.B.6.7 ... as a result I get
169.254.232.149 IP ...
158    36    0.0.0.0    255.255.255.255    DHCP    342    DHCP Discover - Transaction ID 0x4a7f26ee
159    37    A.B.6.254    A.B.6.7    DHCP    345    DHCP Offer    - Transaction ID 0x4a7f26ee
160    37    0.0.0.0    255.255.255.255    DHCP    379    DHCP Request  - Transaction ID 0x4a7f26ee
161    37    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/6/00:12:00:cf:8e:80
162    39    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/6/00:12:00:cf:8e:80
163    39    A.B.6.159    A.B.6.255    NBNS    92    Name query NB WPAD<00>
164    40    A.B.6.159    A.B.6.255    NBNS    92    Name query NB WPAD<00>
165    41    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/6/00:12:00:cf:8e:80
166    41    A.B.6.159    A.B.6.255    NBNS    92    Name query NB WPAD<00>
167    41    A.B.6.159    A.B.6.255    NBNS    92    Name query NB WPAD<00>
168    41    0.0.0.0    255.255.255.255    DHCP    379    DHCP Request  - Transaction ID 0x4a7f26ee
169    42    A.B.6.159    A.B.6.255    NBNS    92    Name query NB WPAD<00>
170    43    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/6/00:12:00:cf:8e:80
171    43    A.B.6.159    A.B.6.255    NBNS    92    Name query NB WPAD<00>
172    45    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/6/00:12:00:cf:8e:80
173    45    G-ProCom_01:39:4b    Broadcast    ARP    60    Who has A.B.6.254?  Tell A.B.6.53
174    46    A.B.2.231    A.B.6.152    ICMP    69    Echo (ping) request  id=0x000c, seq=15064/55354, ttl=12
175    46    G-ProCom_01:38:d6    Broadcast    ARP    60    Who has A.B.6.254?  Tell A.B.6.158
176    46    G-ProCom_01:39:4b    Broadcast    ARP    60    Who has A.B.6.254?  Tell A.B.6.53
177    46    Hewlett-_1f:3e:43    Broadcast    ARP    60    Who has A.B.6.254?  Tell A.B.6.160
178    47    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/6/00:12:00:cf:8e:80
179    47    Hewlett-_1f:3e:43    Broadcast    ARP    60    Who has A.B.6.254?  Tell A.B.6.160
180    47    G-ProCom_01:39:4b    Broadcast    ARP    60    Who has A.B.6.254?  Tell A.B.6.53
181    48    G-ProCom_01:39:4b    Broadcast    ARP    60    Who has A.B.6.254?  Tell A.B.6.53
182    48    A.B.2.231    A.B.6.152    ICMP    69    Echo (ping) request  id=0x000c, seq=15073/57658, ttl=12
183    49    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/6/00:12:00:cf:8e:80
184    49    0.0.0.0    255.255.255.255    DHCP    379    DHCP Request  - Transaction ID 0x4a7f26ee
185    50    A.B.6.53    A.B.6.255    NBNS    92    Name query NB HPFEFC74<00>
186    50    A.B.6.53    A.B.6.255    NBNS    92    Name query NB HPFEFC74<00>
187    51    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/6/00:12:00:cf:8e:80
188    51    169.254.232.149    169.254.255.255    NBNS    92    Name query NB NAME000XNAS1<20>
189    51    A.B.6.53    A.B.6.255    NBNS    92    Name query NB HPFEFC74<00>
190    52    G-ProCom_01:36:67    Broadcast    ARP    60    Who has A.B.6.254?  Tell A.B.6.98
191    52    169.254.232.149    169.254.255.255    NBNS    92    Name query NB NAME000XNAS1<20>
maria.melendez Sun, 03/04/2012 - 15:11
When connecting from same vlan as DHCP A.B.100.200 and I get IP from DHCP  A.B.100.29
685    267    0.0.0.0    255.255.255.255    DHCP    342    DHCP Discover - Transaction ID 0x7bdaf064
686    267    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/101/00:12:00:cf:8e
687    269    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/101/00:12:00:cf:8e
688    271    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/101/00:12:00:cf:8e
689    272    0.0.0.0    255.255.255.255    DHCP    342    DHCP Discover - Transaction ID 0x7bdaf064
690    273    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/101/00:12:00:cf:8e
691    275    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/101/00:12:00:cf:8e
692    277    169.254.232.149    169.254.255.255    NBNS    92    Name query NB LEEEFSSECLXNAS1<20>
693    277    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/101/00:12:00:cf:8e
694    278    169.254.232.149    169.254.255.255    NBNS    92    Name query NB LEEEFSSECLXNAS1<20>
695    278    169.254.232.149    169.254.255.255    NBNS    92    Name query NB LEEEFSSECLXNAS1<20>
696    279    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/101/00:12:00:cf:8e
697    280    0.0.0.0    255.255.255.255    DHCP    342    DHCP Discover - Transaction ID 0x7bdaf064
698    281    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/101/00:12:00:cf:8e
699    284    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/101/00:12:00:cf:8e
700    286    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/101/00:12:00:cf:8e
701    287    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. Root = 49152/101/00:12:00:cf:8e
702    288    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. TC + Root = 49152/101/00:12:00:
703    288    Cisco_cf:8e:cf    Broadcast    ARP    60    Who has A.B.100.199?  Tell A.B.100.254
704    289    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. TC + Root = 49152/101/00:12:00:
705    290    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. TC + Root = 49152/101/00:12:00:
706    292    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. TC + Root = 49152/101/00:12:00:
707    292    Hewlett-_4e:32:14    Broadcast    ARP    60    Who has A.B.100.11?  Tell A.B.100.14
708    294    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. TC + Root = 49152/101/00:12:00:
709    295    Cisco_cf:8e:cf    Broadcast    ARP    60    Who has A.B.100.199?  Tell A.B.100.254
710    295    0.0.0.0    255.255.255.255    DHCP    342    DHCP Discover - Transaction ID 0x7bdaf064
711    295    Hewlett-_3b:48:53    Broadcast    ARP    60    Who has A.B.100.2?  Tell A.B.100.101
712    295    Hewlett-_38:51:9a    Broadcast    ARP    60    Who has A.B.100.101?  Tell A.B.100.2
713    295    Hewlett-_3b:48:53    Broadcast    ARP    60    Who has A.B.100.15?  Tell A.B.100.101
714    295    Hewlett-_d2:d7:9a    Broadcast    ARP    60    Who has A.B.100.101?  Tell A.B.100.15
715    295    Hewlett-_3b:48:53    Broadcast    ARP    60    Who has A.B.100.29?  Tell A.B.100.101
716    296    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. TC + Root = 49152/101/00:12:00:
717    297    Hewlett-_3b:48:53    Broadcast    ARP    60    Who has A.B.100.29?  Tell A.B.100.101
718    297    Hewlett-_4e:32:14    Broadcast    ARP    60    Who has A.B.100.58?  Tell A.B.100.14
719    298    Cisco_a8:6d:d3    Spanning-tree-(for-bridges)_00    STP    60    Conf. TC + Root = 49152/101/00:12:00:
720    298    A.B.100.200    255.255.255.255    DHCP    354    DHCP Offer    - Transaction ID 0x7bdaf064
721    298    0.0.0.0    255.255.255.255    DHCP    379    DHCP Request  - Transaction ID 0x7bdaf064
722    298    A.B.100.200    255.255.255.255    DHCP    359    DHCP ACK      - Transaction ID 0x7bdaf064
723    298    A.B.100.29    224.0.0.22    IGMP    54    V3 Membership Report / Join group 224.0.0.252 for any so
724    298    A.B.100.29    224.0.0.22    IGMP    54    V3 Membership Report / Leave group 224.0.0.252
Richard Burts Sun, 03/04/2012 - 15:43
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Maria
Thanks for posting the packet captures. I am afraid that they do not shed much light on the problem. They show that the machine in VLAN 6 is sending requests but gets no response and that the machine in the same VLAN as the server does get a response. But we pretty much knew this already.
I do find it interesting that the machine in the same VLAN as the server sends multiple requests. The first three requests do not get any response. It is only after the fourth request that the client gets a response from the server.
Can you tell us how the server is connected? Is it connected to a port on one of the switches that you have mentioned? Would it be possible to get a span port configured to monitor the traffic going to the server and responses from the server?
Rick
maria.melendez Sun, 03/04/2012 - 16:07
We have the main router 3750 and a couple of 4506 in different floors. The server is connected to one of the 4506.
I dont know how to do a span port, do you have a link to a document with more info ?
Thank you so much for all your help!!
-Maria
Richard Burts Sun, 03/04/2012 - 17:37
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Maria
The link given by Reza is a good one. You would want to set up span/monitor with the port where the server is connected as the source and some available port as the destination. Then you would connect a PC that can run Wireshark to the destination port and do the packet capture. We would want the capture to verify whether the DHCP request is sent to the server and what, if any, response is sent by the server.
Rick
acampbell Mon, 03/05/2012 - 02:29
Maria,
Also post the config of the port that is connected to the DHCP server
Alex
maria.melendez Mon, 03/05/2012 - 08:36
Thank you all for your posts, sorry for my delay in replying ...
After 3.5 hrs in the phone with Cisco, the problem is resolved.
1) One machine was broadcasting arp messages to all the network creating a high CPU utilization (router).
2) After that machine was disabled the network started to be stable again, but DHCP problem wasn't resolved.
3)Then we turned off the VTP pruning, DHCP problem was resolved and machines were able to get IP by DHCP.
The machine that was creating the traffic is a UNIX box with dual NIC, the first NIC with static IP in vlan 13 and 2nd NIC with an IP in a non-routable vlan(192.168.x.x). Another UNIX box in the same vlan (13) was using the same non-routable IP (192.168.x.x) causing the conflict with IP address and letting one machine sent out all the arp requests.
Thanks for your valuable time !
-M
Correct Answer
Richard Burts Mon, 03/05/2012 - 11:16
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Maria
Rick
