Warning message
L2L and DMVPN on one device
Mar 4th, 2012
Hi.
My topology is as below:
What I'm trying to configure is site-to-site VPN R5-R1  and site-to-site VPN R3-R1. The main problem is that interface f0/0 of R5 has dynamiclly assigned IP address and it is being changed once a day (is just lab topology so just for now I assigned static IP of int f0/0 of R5) . R3 has static public IP.
The idea was to use isakmp profiles, so my configuration was like this (attached just R1, R3 and R5 using standard site-to-site vpn configuration)
R1:
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
crypto keyring KEY_R3
  pre-shared-key address 200.1.1.3 key 6 ciscor3
crypto keyring KEY_R5
  pre-shared-key address 0.0.0.0 0.0.0.0 key 6 ciscor5
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp profile PROFIL_R3
   keyring KEY_R3
   match identity address 200.1.1.3 255.255.255.255
crypto isakmp profile PROFIL_R5
   keyring KEY_R5
   match identity address 0.0.0.0
crypto ipsec transform-set setr3 esp-3des esp-sha-hmac
crypto ipsec transform-set setr5 esp-3des esp-sha-hmac
crypto dynamic-map DYN_MAPA 10
set transform-set setr3
set isakmp-profile PROFIL_R3
crypto dynamic-map DYN_MAPA 100
set transform-set setr5
set isakmp-profile PROFIL_R5
crypto map MAPA 65535 ipsec-isakmp dynamic DYN_MAPA
interface Loopback0
interface FastEthernet0/0
ip address 100.1.1.1 255.255.255.0
duplex auto
speed auto
crypto map MAPA
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 100.1.1.2
no ip http server
no ip http secure-server
ip access-list extended do_r3
permit ip 192.168.1.0 0.0.0.255 172.16.1.0 0.0.0.255
control-plane
gatekeeper
shutdown
line con 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
end
Configuration attached above works just fine ! But only because I configure isakmp profile PROFIL_R3 as first. When I changed my configuration like this:
   keyring KEY_R5
   keyring KEY_R3
Router R3 cannot establish connection to R1. Debug said that R3 matches PROFIL_R5 (that true, because PROFIL_R5 has identity match add 0.0.0.0) and its key doesn't match.
While reading article about ISAKMP Profiles :
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6635/prod_white_paper0900aecd8034bd59.html
i found this sentence:
"To uniquely map to an ISAKMP profile, no two  ISAKMP profiles should match the same identity. If the peer identity is  matched in two ISAKMP profiles, the configuration is invalid."
And  in my topology R3 matches to both profiles ! So i can not find a solution to this problem. Changing sequence of Profile configuration is not an answer, because when I would need to add another site-to-site VPN I would need to delete PROFIL_R5, add new profile and then add PROFIL_R5 again.
In article above i didn't find an information how router checks multiple profiles (first match ? best match? last match?). Can anybody gives me a clue how to set up my topology correctly ?
Thanks in advance.
