Issue With Posting
Answered Question
Mar 4th, 2012
Hi Dan and the support team,
I have noticed this behavior several times in the past, but I want to provide an example for clarity.  If you click on this URL, it is discussion about VRF leaking that have provided feedback to.  Usually, when I provide feedback my name will replace the OP's name on the right side in the main page.  In this case the OP's name is still there and not mine.  I am wondering if this a software issue and if anyone else has noticed it?
I have to say that this is not very common at all, but it has happened to me a few times.
Again, not big deal at all, but I want to bring it to your attention.
https://supportforums.cisco.com/thread/2135675?tstart=0
Reza
Correct Answer by Daniel Bruhn about 4 years 11 months ago
Hi Reza,
I just ran some tests and identified the cause of what you are describing.  The original author is making an edit to their post after you respond.  When this happens it makes them appear on main page as the last person to touch the discussion.  I'm guessing  the edit is so small you aren't even recognizing it occurred.  This isn't actually a bug,  but I see how it can be confusing if it's only a minor edit.
Cheers,
Dan
Overall Rating: 5 (5 ratings)
Correct Answer
Daniel Bruhn Mon, 03/05/2012 - 09:09
Hi Reza,
Cheers,
Dan
