Warning message
Cisco ACE question
Mar 4th, 2012
I have some question.
1. Is ACE 4710 whether there has equipment failure bypass function?
2. Real Server, whether there is a limit on the number? Server in the server farm whether there is a limit on the number? VIP whether there is a limit on the number?
3. If ACE 4710 failure, which it can support alarm mechanism such as e-mail? Or can use other network management software?
Billy
Diego Vargas Mon, 03/05/2012 - 10:07
  • Cisco Employee,
Let me find point 1 and 2, point 3 below
3.
You can configure syslog messages to be sent to different  locations, including a syslog server which usually has the capacity to  send e-mail notifications:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA4_2_0/configuration/system/message/guide/config.html#wp1063710
In case of failure, you can also configure SNMP traps to be sent, details below:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA4_2_0/configuration/administration/guide/snmp.html#wp1005578
