figueirt Tue, 03/06/2012 - 13:04
Hi, I also have trouble logging in but only behind the corporate firewall and I haven't found any documentation as to what they try to do and on what ports.
adamar Fri, 03/09/2012 - 06:53
I have the same problem. Opening ports given in the Document 23195 did not resolve the issues. Our firewall is Cisco ASA.
Thank you
~Adam
Hoan Mai Fri, 03/09/2012 - 09:29
Hi Adam,
1. Before you logged into CJV, there's a sign-in settings, please post the screen capture of the window.
2. You downloaded the installer from the sign-up page correct?  This will not work if you use other
variations of jabber/movi @ cisco.com page.
Rick Mai
adamar Fri, 03/09/2012 - 11:02
This is the screenshot of the sign-in settings
yes i did download the client from the page and i do not have any other jabber or movi client on that pc. Also keep in mind that the same download did work without a problem on my home computer.
Thank you
~Adam
Hoan Mai Fri, 03/09/2012 - 11:08
Hi Adam,
put in a . (period) in the SIP Domain field and try.
Rick Mai
adamar Fri, 03/09/2012 - 11:09
unfortunately i cannot edit the fields in the settings
~Adam
Hoan Mai Fri, 03/09/2012 - 11:24
hmm,
missing a period is not good.  Try un-install and re-install the app to see if you can see the . re-populate.
Rick M
adamar Fri, 03/09/2012 - 11:49
Still no period thou i just checked my home computer and there is no period either and it is working there
~Adam
Thank you
~Adam
I have seen this behind our Cisco ASA.   The ASA appears to intercept the TLS traffic to on port 5061 and cause certificate fail errors when the client attempts to register.
From a quick look it appears this may be due to a tls-proxy facility on the ASA, which I assume would require some tweaking to leave this TLS traffic unmunged.
adamar Tue, 03/20/2012 - 06:01
Cisco ASA was the problem. Quick TAC case fixed things right up.
Thank you for pointing me in a right directory.
~Adam
adamar Tue, 03/20/2012 - 10:27
Nikhil
are you using ASA as your firewall??
~Adam
Nikhil Jayan Ka... Wed, 03/21/2012 - 06:25
Yes adam
we are using ASA as the outside first layer firewall and Palo Alto as the second layer firewall.
Nikhil Jayan
adamar Wed, 03/21/2012 - 06:55
the following is the information i needed to change in ASA in order for Jabber to work:
The existing config was:
class-map sec_sip
match port tcp eq 5061
So instead of match the port 5061 we can match an ACL:
Access-list TEST deny ip any host 199.19.190.27
Access-list TEST deny ip host 199.19.190.27 any
Access-list TEST permit tcp any any eq 5061
class-map sec_sip
no match port tcp eq 5061
match access-list TEST
Keep in mind that 199.19.190.27 is the ip address of the JAbber server that we are connecting to.
Let me know if that helped.
Adam
