Warning message
7606 monitor session not working
Mar 6th, 2012
I've setup and configured the following local monitor session on a 7606 but it doesnt seem to be outputing anything.  Any guess as to why, or what I might be doing wrong?  Gi1/1 is doing ~40Mb/s egress & 15Mb/s ingress.  Both source and destination ports are routed ports.
monitor session 10 source interface Gi1/1
monitor session 10 destination interface Gi1/10 ingress
interface GigabitEthernet1/1
description WAN Link to *********************  ** CORE BACKBONE **
mtu 9000
ip address ************** 255.255.255.252
ip mtu 1600
speed nonegotiate
mpls ip
no cdp enable
end
interface GigabitEthernet1/10
description Monitor destination -> Laptop ** TEMP **
no ip address
end
CR01.***#sh int gi1/10
GigabitEthernet1/10 is up, line protocol is down (monitoring)
  Hardware is C6k 1000Mb 802.3, address is 000a.f331.d700 (bia 000a.f331.d700)
  Description: Monitor destination -> Laptop ** TEMP **
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 236/255, txload 1/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is T
  input flow-control is off, output flow-control is off
  Clock mode is auto
  Last input 00:12:41, output 00:12:34, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 110 pkt, 10656 bytes
  L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 0 pkt, 0 bytes mcast: 0 pkt, 0 bytes
     181 packets input, 17232 bytes, 0 no buffer
     Received 181 broadcasts (0 IP multicasts)
     55 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     42 packets output, 15262 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Edison Ortiz Tue, 03/06/2012 - 06:10
  • Hall of Fame,
    Founding Member
Per the documentation:
http://www.cisco.com/en/US/docs/routers/7600/ios/12.2SR/configuration/guide/span.html
When configuring destinations with the ingress and learning keywords, note the following:
Configure the destinations for Layer 2 switching
Currently, your switchport is configured as Layer3 port. You must enter the command switchport under G1/10
