Warning message
adding custom table
Mar 6th, 2012
The goal is to add a table where some custom parameters will be stored in order to speed up custom SQL queries.
Is it allowed/recommended to add a custom table to the HDS database?
Is it possible to add a table to the CUIC database? Is it possible to access the CUIC database?
Justine.
david.macias Tue, 03/06/2012 - 08:02
  • Blue, 1500 points or more
I would not add any tables to the HDS DB, pretty sure it's not supported.  As for the CUIC database, I don't think you have access to the actual DB itself.  Why don't you just build the table in another DB and create a new datasource in CUIC to pull data from this table?
david
justine.joubran Tue, 03/06/2012 - 12:20
Thanks for the reply David.
Since CUIC does not support 2 datasources for a single reports, I would need to create a view. Do you agree?
Justine.
boyd.lynn Wed, 03/07/2012 - 03:46
Justine,
That's exactly how I have done this in the past. In theory my Custom Views could get removed when I do an upgrade but  I will just recreate them.
Cheers
Boyd
Related Content
