How to update a device package in LMS 4.1
Answered Question
Mar 6th, 2012
I am adding SUP 2 T's  into the network and need to have LMS monitoring them. I have not yet been able to figure out where to upgrade the device package so that I can add the SUP 2 T's
Correct Answer by yjdabear about 4 years 11 months ago
Admin -> System -> Software Center -> Device Update
Following the documenation below regarding "Performing Device Update":
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/user/guide/admin/swcenter.html#wp1096972
Overall Rating: 5 (1 ratings)
Mike Mott Thu, 03/22/2012 - 09:02
Your first suggestion seemed to work in that I was able to update the Cat6000IOS package from ver 34 to ver 35 in the "CiscoView "
However I am sure there is something more that I need to do. We have upgraded to 6513's to 6513-E . After the upgrades I went to device center to determine if I was seeing the 15.0 IOS now, and I am still seeing the old 12.18 code. I deleted the device and readded it and in so doing I saw there was no option for a 6513-E switch. Just the 6513. What do I need to do to be able to add this switch as a 6513-E. I did look at Inventory Config And Image Management  in device updates and found it is at ver 11.0 for CAT6000IOS. Any help would be appreciated.
yjdabear Thu, 03/22/2012 - 10:00
Yeah, for Inventory Config And Image Management (the traditional RME functions, in LMS 3.x lingo), you have to perform a separate "Software Update" (vis-a-vis Device Update, which is apparently for CiscoView). That's described in the same aforementioned URL, a little further up, Admin -> System -> Software Center -> Software Update:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/user/guide/admin/swcenter.html#wp1096852
The following page describes, in not-so-clear terms, whether it's Software Update or Device Update that's needed to get newer hw/sw recognized by the various pieces of LMS 4.1.
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/device_support/table/lms41sdt.html
