C3KX-PWR-1100WAC= compatible with WS-C3750X-24P-S?
Answered Question
Mar 6th, 2012
Is the C3KX-PWR-1100WAC= compatible with the WS-C3750X-24P-S?
Correct Answer by hobbe about 5 years 5 months ago
Yes it is compatible.
Just note that the 1100wac powersupply sticks out a bit from the chassie about 3-4 cm.
Good luck
Overall Rating: 5 (1 ratings)
Correct Answer
hobbe Tue, 03/06/2012 - 12:34
  • Gold, 750 points or more
Good luck
