filtering log messages
Mar 6th, 2012
I'm attempting to debug an ipsec tunnel on an ASA 5510 (8.4(3)) and when I turn on `debug crypto ipsec` and then execute `logging monitor` I get an constant stream of TCP debugging events, is it possible to only view ipsec messages?
mikeburr1234 Wed, 04/11/2012 - 19:30
Have you tried using the debug crypto condition commands:
ciscoasa# debug crypto condition ?
  error      Display debug error messages regardless of filters
  group      Filter on a group name
  peer       Filter on a peer address or subnet
  reset      Clear the crypto debug filters
  spi        Filter on an IPSec SPI
  unmatched  Display messages with insufficient context to match a filter
  user       Filter on a user name
kamran_Roostaee Sun, 04/15/2012 - 01:05
It seems that you are using VPN, so if you want to check tunnel you can use show and debug but you should classify problem, if you have security issue you can use Show Crypto isakmp sa that shows isakmp operational data but if you want to see isakmp detailed negoiation you can use debug crypto isakmp , but if problem is related to ipsec tunnel you can use show crypto ipsec sa or debug crypto ipsec  but you can add debug level at the end of command, default is 1 for example you can use debug crypto ipsec 7 to debug detailed ipsec negotiations.
Related Content
