ANM Sync Failed v5.2
Answered Question
Mar 6th, 2012
Anyone else experiencing this problem with "Sync Failed"?
This is the error i get when I try a manual CLI Sync.
Clint
Correct Answer by Diego Vargas about 2 years 1 month ago
Hey Clint,
Thats exactly where I was going with my question. I can't find which specifics are supported but I found some already seen issues with "#"  on hostname and other config parameters.
Average Rating: 5 (1 ratings)
pipaulo Tue, 03/06/2012 - 22:24
Hi Clint,
For interest sake, is the the Virtual Appliance or not? Was this a new installation, or an upgrade?
Also will follow this as am planning to upgrade a customer to 5.2 and would not like to introduce issues like this.
Paul.
csimmons@appros... Wed, 03/07/2012 - 06:22
This is a new install of the binary file on a fresh install of Redhat v5.8
I also had this same problem with ANM v5.1.
-Clint
Diego Vargas Wed, 03/07/2012 - 15:06
Hi Clint,
Are you getting the error when syncing with the ACE? Have you configured any special characters on probes, authgroup, or somewhere else in the device config?
csimmons@appros... Wed, 03/07/2012 - 15:16
You bring up a good point.. I read this in the docs..
Note
When  naming ACE objects (such as a real server, virtual server, parameter  map, class map, health probe, and so on), enter an alphanumeric string  of 1 to 64 characters, which can include the following special  characters: underscore (_), hyphen (-), dot (.), and asterisk (*).  Spaces are not allowed.
If you are using ANM with an ACE module  or ACE appliance and you configure a named object at the ACE CLI, keep  in mind that ANM does not support all of the special characters that the  ACE CLI allows you to use when configuring a named object. If you use  special characters that ANM does not support, you may not be able to  import or manage the ACE using ANM.
What is doesn't say is which characters exactly are not supported..
I can tell you I use "#" which is not in the list above. If "#" is the problem then I'm in bad shape as between my revenue, non-revenue and DR contexts (almost 30). I'm using it in everything!!
Correct Answer
Diego Vargas Wed, 03/07/2012 - 15:34
Hey Clint,
csimmons@appros... Tue, 03/13/2012 - 09:04
I created a new context yesterday and without the "#"'s it's syncing without any issues.
I will 100% verify if it's the #'s shortly.
Login or Register to take actions
Posted March 6, 2012 at 3:14 PM
Stats:
Replies:7 Avg. Rating:5
Views:768 Votes:0
Shares:0
Related Content
Discussions Leaderboard
Rank Username Points
1 1,551
2 369
3 333
4 228
5 212
