Warning message
Call forwarding status in CUCM 8.5.1
Jaime Valencia Wed, 03/07/2012 - 06:19
  • Cisco Employee,
  • Hall of Fame,
    2011
No you would either need to export the info with BAT (this will include ALL phones so you then need to sort them out) or if you really want the ones with CFA run some qrys via CLI for this.
There are already some queries for that on CSC so if you take some time to search you'll find them.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
