NAC CSR Request
Mar 8th, 2012
It's time to renew my enduser certs on my CAM.
I know I need to generate a CSR and that the process says that I should click on the Generate Certificate Request button to create the request.
I also see that I have two line above the button that read:
Certification Request:   CN and all the information
Private Key: RSA, 1024 bits
If the information is correct and nothing has changed can I simply click and export those two files?
Thanks!
Bob
