Warning message
LMS 4.1 : 0 Devices in Campus Manager (VLAN Port Assignment, ...) Bug ?
Answered Question
Mar 8th, 2012
Hi guys,
I encountered again a problem with the new virtual appliance of Cisco Prime LMS 4.1.
My appliance is installed, licence embedded, and several devices added into the DCR.
If I'm going on the Inventory > Manage Device State, I can find ALL my added devices (I use hostname, without appending DNS domain).
But into the Campus Manager , for example into : Configuration > Workflows > VLAN > Port Vlan Assignment , I don't have any devices in !
Well, I tried many times to Run a Data Collection on "All Devices", but nothing more...
If I go to Admin > Collection Settings > Data Collection  --> Show Devices --> Always the same devices into it ... nearly 20 devices, and I have much more than 20 devices into my network !!
How could I solve this issue please ?
It 's really annoying, because we cannot manage PORT VLAN ASSIGNMENT from LMS on the devices...
Thank a lot for your answer.
Stephane.
Correct Answer by Michel Hegeraat about 5 years 5 months ago
When the devices don't get 'data collected' they will just not appear there
Nothing under (VTP) domain selector either then?
Not sure what could cause this. I think a problem with the ani db.
You can reinit or do a dbrestoreorig. See the forum documents for details
Cheers,
Michel
Overall Rating: 5 (1 ratings)
Correct Answer
Michel Hegeraat Fri, 03/09/2012 - 02:51
  • Gold, 750 points or more
Cheers,
Michel
Stephane LACHAPELLE Tue, 03/20/2012 - 06:16
Hi Michel,
Correct !
Thank you very much for your help.
Indeed, it was an ANIdb related issue.
What I made :
[SVR-LANMGT01/root-ade init.d]# ./dmgtd stop
Daemon Management stopping. This may take a few minutes.
[SVR-LANMGT01/root-ade bin]# dbRestoreOrig.pl dsn=ani dmprefix=ANI
WARNING: Existing contents of ani database will be lost.
Do you want to continue [y/n]?y
INFO: Starting the DataBase
    Starting database engine aniEng
SQL Anywhere Command File Hiding Utility Version 10.0.1.4157
INFO: Start Db Engine /opt/CSCOpx/objects/db/bin64/dbeng10 -q -x tcpip{HOST=localhost;DOBROADCAST=NO;ServerPort=43443} -m -ud -c 16M -n aniEng /opt/CSCOpx/databases/ani/ani.db -n aniDb
INFO: select count(*) from DbVersion, select count(*) from func_config : Retry 0
INFO: Connected the Database
INFO: Command Executed
INFO: Connecting the Database ani
INFO: Company=Cisco Systems;Application=NMTG;Signature=010fa55157edb8e14d818eb4fe3db41447146f1571g32125eb777a87cbf8b29a954f559d4221b792ff8
INFO: Preparing AUTH cmd
INFO: AUTH Executed
INFO: AUTH cmd finished
INFO: Stopping the Database engine ani
    Stopping database engine aniEng
INFO:STOP= /opt/CSCOpx/objects/db/bin64/dbstop -q -y -c dsn=ani
INFO: Database Shutdown is in Progress..Please wait
INFO: Stop Engine Args= /opt/CSCOpx/objects/db/bin64/dbstop -q -y -c dsn=ani
INFO: After Database Shutdown RC= 0
INFO: Database [ani] authenticated successfully.
ani database initialization is completed.
[SVR-LANMGT01/root-ade bin]# /etc/init.d/dmgtd start
WARNING: Insufficient Memory (RAM). Please refer to the
WARNING: prerequisites chapter of the install guide.
INFO:backed up /var/adm/CSCOpx/log/daemons.log to /var/adm/CSCOpx/log/daemonsbackup.log
Daemon Management 4.1 starting. Log=(syslog) /var/adm/CSCOpx/log/dmgtd.log
Then with the WebUI a new Data Collection + Major Acquisition.
It has solved my problem.
Thank you.
Related Content
