Warning message
Ospf from LOADING to FULL, Loading Done message
Mar 8th, 2012
Hi All,
Am getting a message :
Mar  7 07:02:46.934: %OSPF-5-ADJCHG: Process 500, Nbr 10.130.240.58 on GigabitEthernet0/49 from LOADING to FULL, Loading Done
Mar  7 07:04:06.249: %OSPF-5-ADJCHG: Process 500, Nbr 10.130.240.58 on GigabitEthernet0/49 from LOADING to FULL, Loading Done
Mar  7 07:04:47.966: %OSPF-5-ADJCHG: Process 500, Nbr 10.130.240.58 on GigabitEthernet0/49 from LOADING to FULL, Loading Done
Mar  7 07:06:34.527: %OSPF-5-ADJCHG: Process 500, Nbr 10.130.240.58 on GigabitEthernet0/49 from LOADING to FULL, Loading Done
Mar  7 07:06:58.964: %OSPF-5-ADJCHG: Process 500, Nbr 10.130.240.58 on GigabitEthernet0/49 from LOADING to FULL, Loading Done
But am not finding any clue as my network is consistent and no flap is observed.
thanks in advance.
Sanjay
Overall Rating: 5 (1 ratings)
John Blakley Thu, 03/08/2012 - 11:06
  • Purple, 4500 points or more
You're losing your neighborship somehow. Can you post "sho ip ospf neigh"?
Sanjay Shaw Thu, 03/08/2012 - 11:14
Hi J,
Neighbor ID     Pri   State           Dead Time   Address         Interface
10.130.148.3      1   FULL/DROTHER    00:00:31    10.130.146.50   Vlan20
10.130.240.54     1   FULL/DR         00:00:37    10.130.146.52   Vlan20
10.130.148.3      1   FULL/DROTHER    00:00:31    10.130.146.28   Vlan10
192.168.1.1       1   FULL/BDR        00:00:33    10.130.146.25   Vlan10
10.130.240.58     0   FULL/  -        924 msec    10.120.106.246  GigabitEtherne
10.130.240.58     0   FULL/  -        924 msec    10.120.106.246  GigabitEthernet0/49
Sanjay
John Blakley Thu, 03/08/2012 - 11:29
Sanjay,
Can you post "sho ip ospf neigh detail g0/49"
Sanjay Shaw Thu, 03/08/2012 - 11:58
Hi j,
Please find the show ip ospf neigh detail g0/49
Neighbor 10.130.240.58, interface address 10.120.106.246
    In the area 10 via interface GigabitEthernet0/49
    Neighbor priority is 0, State is FULL, 1978 state changes
    DR is 0.0.0.0 BDR is 0.0.0.0
    Options is 0x12 in Hello (E-bit L-bit )
    Options is 0x52 in DBD (E-bit L-bit O-bit)
    LLS Options is 0x1 (LR)
    Dead timer due in 782 msec
    Neighbor is up for 1d18h
    Index 1/1, retransmission queue length 0, number of retransmission 89
    First 0x0(0)/0x0(0) Next 0x0(0)/0x0(0)
    Last retransmission scan length is 1, maximum is 35
    Last retransmission scan time is 0 msec, maximum is 0 msec
John Blakley Thu, 03/08/2012 - 12:12
You definitely have an issue:
What is the device off of G0/49? This can be a L2 issue. You may want to run 'debug ip ospf adj' to see what's going on. Can you see all of your ospf neighbors if you ping 224.0.0.5 from this device?
fb_webuser Thu, 03/08/2012 - 12:17
  • Silver, 250 points or more
Do you have logging of OSPF neighbors enabled?
router ospf
ospf log-adjacency-change
And, if you are able to debug:
  1. debug ip ospf adjacency
Check out what the logs say, see if you can find a cause for the constant SPF calculations and adjacency flapping.
Post the results of the log, as well as the results from "show interface G0/49"
Atle
Posted by WebUser Atle Ørn Hardarson
Sanjay Shaw Thu, 03/08/2012 - 12:31
We can't enable the debug as of now as we have a production running over it.
Kindly find the ping status to 224.0.0.5 and sh int g0/49 .
ping 224.0.0.5
Reply to request 0 from 10.130.146.52, 8 ms
Reply to request 0 from 10.120.106.246, 8 ms
Reply to request 0 from 10.130.146.50, 8 ms
Reply to request 0 from 10.130.146.28, 8 ms
Reply to request 0 from 10.130.146.53, 8 ms
We heard reply from all ospf neighbor.
sh int g0/49
GigabitEthernet0/49 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 001e.796d.4446 (bia 001e.796d.4446)
  Description: ##conn-to-WT-CORE-sw-I##
  Internet address is 10.120.106.245/30
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 17w1d
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 3000 bits/sec, 4 packets/sec
  5 minute output rate 1323000 bits/sec, 717 packets/sec
     1265034308 packets input, 409235972158 bytes, 0 no buffer
     Received 42824721 broadcasts (0 IP multicasts)
     0 watchdog, 42824721 multicast, 0 pause input
     16926547531 packets output, 3472153867741 bytes, 0 underruns
Sanjay Shaw Thu, 03/08/2012 - 12:18
Hi J,
Our end we have G0/49 on cisco 3560 switch connected with 6500 switch on to other co-operate end.
Sanjay
John Blakley Thu, 03/08/2012 - 12:23
This can be a L2 issue. You may want to run 'debug ip ospf adj' to see  what's going on. Can you see all of your ospf neighbors if you ping  224.0.0.5 from this device? Also, you may look at the link between the 3750 and 6500 to see if there are crc errors or anything like that. You could post 'sh int g0/49' also...
fb_webuser Sun, 03/11/2012 - 08:52
Even if you are in a production environment, you could use debugging with conditioning (debug condition interface g0/49 and debug ip ospf adj).
Sanjay Shaw Sun, 03/18/2012 - 17:29
Hi Folks,
Please find the debug output.
Log Buffer (4096 bytes):
    aid:0.0.0.10 chk:F649 aut:0 auk: from GigabitEthernet0/49
42w6d: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:01:13 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:01:14 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
--More--                           Mar 17 07:01:14 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:01:14 IST: OSPF: rcv. v:2 t:1 l:52 rid:10.130.148.3
      aid:0.0.0.4 chk:B3AD aut:0 auk: from Vlan10
      aid:0.0.0.4 chk:7A6D aut:0 auk: from Vlan20
Mar 17 07:01:15 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:01:15.523: %SYS-5-CONFIG_I: Configured from console by vty2 (10.120.106.237)
Mar 17 07:01:16 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
--More--                           Mar 17 07:01:17 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:01:17 IST: OSPF: rcv. v:2 t:1 l:52 rid:192.168.1.1
      aid:0.0.0.4 chk:C3AD aut:0 auk: from Vlan10
Mar 17 07:01:18 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:01:19 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:02:11 IST: OSPF: rcv. v:2 t:1 l:52 rid:10.130.240.54
      aid:0.0.0.4 chk:8A6D aut:0 auk: from Vlan20
Mar 17 07:02:11 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:02:12 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:02:13 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
--More--                                 aid:0.0.0.10 chk:F649 aut:0 auk: from GigabitEthernet0/49
Mar 17 07:02:14 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:02:14 IST: OSPF: rcv. v:2 t:2 l:32 rid:10.130.240.58
      aid:0.0.0.10 chk:97DA aut:0 auk: from GigabitEthernet0/49
Mar 17 07:02:14 IST: OSPF: Rcv DBD from 10.130.240.58 on GigabitEthernet0/49 seq 0x1359 opt 0x52 flag 0x7 len 32  mtu 1500 state FULL
Mar 17 07:02:14 IST: OSPF: Bad seq received from 10.120.106.246 on GigabitEthernet0/49
Mar 17 07:02:14 IST: OSPF: Send DBD to 10.130.240.58 on GigabitEthernet0/49 seq 0x15AE opt 0x52 flag 0x7 len 32
Mar 17 07:02:14 IST: OSPF: rcv. v:2 t:2 l:1452 rid:10.130.240.58
      aid:0.0.0.10 chk:6D8A aut:0 auk: from GigabitEthernet0/49
Mar 17 07:02:14 IST: OSPF: Rcv DBD from 10.130.240.58 on GigabitEthernet0/49 seq 0x15AE opt 0x52 flag 0x2 len 1452  mtu 1500 state EXSTART
Mar 17 07:02:14 IST: OSPF: NBR Negotiation Done. We are the MASTER
Mar 17 07:02:14 IST: OSPF: Send DBD to 10.130.240.58 on GigabitEthernet0/49 seq 0x15AF opt 0x52 flag 0x3 len 1452
Mar 17 07:02:14 IST: OSPF: rcv. v:2 t:4 l:76 rid:10.130.240.58
      aid:0.0.0.10 chk:5C8D aut:0 auk: from GigabitEthernet0/49
--More--                           Mar 17 07:02:14 IST: OSPF: Rcv LS UPD from 10.130.240.58 on GigabitEthernet0/49 length 76 LSA count 1
Mar 17 07:02:14 IST: OSPF: Build router LSA for area 10, router ID 10.130.240.60, seq 0x8000348D, process 500
Mar 17 07:02:15 IST: OSPF: rcv. v:2 t:1 l:52 rid:10.130.148.3
Mar 17 07:02:15 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:02:16 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:02:27 IST: OSPF: Generate external LSA 10.113.181.0, mask 255.255.255.0, type 5, age 0, metric 2, tag 0, metric-type 2, seq 0x80000001
Mar 17 07:02:27 IST: OSPF: Generate external LSA 10.142.0.0, mask 255.255.0.0, type 5, age 0, metric 1, tag 9730, metric-type 2, seq 0x80000001
Mar 17 07:02:27 IST: OSPF: Generate external LSA 10.200.0.0, mask 255.255.0.0, type 5, age 0, metric 1, tag 9730, metric-type 2, seq 0x80000001
Mar 17 07:02:27 IST: OSPF: Generate external LSA 10.201.0.0, mask 255.255.0.0, type 5, age 0, metric 1, tag 9730, metric-type 2, seq 0x80000001
Mar 17 07:02:27 IST: OSPF: Generate external LSA 10.207.0.0, mask 255.255.0.0, type 5, age 0, metric 1, tag 9730, metric-type 2, seq 0x80000001
Mar 17 07:02:27 IST: OSPF: Generate external LSA 192.168.0.0, mask 255.255.0.0, type 5, age 0, metric 1, tag 9730, metric-type 2, seq 0x80000001
Mar 17 07:02:27 IST: OSPF: Generate external LSA 203.91.192.0, mask 255.255.248.0, type 5, age 0, metric 1, tag 9730, metric-type 2, seq 0x80000001
Mar 17 07:02:27 IST: OSPF: Generate external LSA 203.91.218.0, mask 255.255.255.0, type 5, age 0, metric 1, tag 9730, metric-type 2, seq 0x80000001
Mar 17 07:02:27 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:02:27 IST: OSPF: rcv. v:2 t:1 l:52 rid:192.168.1.1
--More--                           Mar 17 07:02:28 IST: OSPF: rcv. v:2 t:4 l:64 rid:10.130.148.3
      aid:0.0.0.4 chk:533B aut:0 auk: from Vlan10
Mar 17 07:02:28 IST: OSPF: Rcv LS UPD from 10.130.148.3 on Vlan10 length 64 LSA count 1
      aid:0.0.0.4 chk:6727 aut:0 auk: from Vlan10
Mar 17 07:02:28 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:02:28 IST: OSPF: rcv. v:2 t:4 l:568 rid:10.130.148.3
      aid:0.0.0.4 chk:3238 aut:0 auk: from Vlan10
Mar 17 07:02:28 IST: OSPF: Rcv LS UPD from 10.130.148.3 on Vlan10 length 568 LSA count 15
Mar 17 07:02:29 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
--More--                           Mar 17 07:02:29 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:02:30 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:02:30 IST: OSPF: rcv. v:2 t:5 l:364 rid:10.130.148.3
      aid:0.0.0.4 chk:4381 aut:0 auk: from Vlan20
Mar 17 07:02:30 IST: OSPF: rcv. v:2 t:5 l:364 rid:10.130.240.54
      aid:0.0.0.4 chk:E74D aut:0 auk: from Vlan20
Mar 17 07:02:30 IST: OSPF: rcv. v:2 t:5 l:364 rid:192.168.1.1
      aid:0.0.0.4 chk:205D aut:0 auk: from Vlan10
Mar 17 07:02:31 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:02:52 IST: OSPF: Generate external LSA 10.200.0.0, mask 255.255.0.0, type 5, age 3600, metric 16777215, tag 9730, metric-type 2, seq 0x80000002
Mar 17 07:02:52 IST: OSPF: Generate external LSA 10.142.0.0, mask 255.255.0.0, type 5, age 3600, metric 16777215, tag 9730, metric-type 2, seq 0x80000002
Mar 17 07:02:52 IST: OSPF: Generate external LSA 10.113.181.0, mask 255.255.255.0, type 5, age 3600, metric 16777215, tag 0, metric-type 2, seq 0x80000002
Mar 17 07:02:52 IST: OSPF: Generate external LSA 10.113.50.0, mask 255.255.255.0, type 5, age 3600, metric 16777215, tag 0, metric-type 2, seq 0x80000002
Mar 17 07:02:52 IST: OSPF: Generate external LSA 10.111.43.0, mask 255.255.255.0, type 5, age 3600, metric 16777215, tag 0, metric-type 2, seq 0x80000002
Mar 17 07:02:52 IST: OSPF: Generate external LSA 10.111.0.0, mask 255.255.0.0, type 5, age 3600, metric 16777215, tag 9730, metric-type 2, seq 0x80000002
Mar 17 07:02:52 IST: OSPF: Generate external LSA 10.107.0.0, mask 255.255.0.0, type 5, age 3600, metric 16777215, tag 9730, metric-type 2, seq 0x80000002
Mar 17 07:02:52 IST: OSPF: Generate external LSA 10.102.208.0, mask 255.255.255.0, type 5, age 3600, metric 16777215, tag 0, metric-type 2, seq 0x80000002
Mar 17 07:02:52 IST: OSPF: Generate external LSA 10.102.0.0, mask 255.255.0.0, type 5, age 3600, metric 16777215, tag 9730, metric-type 2, seq 0x80000002
Mar 17 07:02:52 IST: OSPF: Generate external LSA 10.101.202.0, mask 255.255.255.224, type 5, age 3600, metric 16777215, tag 0, metric-type 2, seq 0x80000002
Mar 17 07:02:52 IST: OSPF: Generate external LSA 10.101.0.0, mask 255.255.0.0, type 5, age 3600, metric 16777215, tag 9730, metric-type 2, seq 0x80000002
Mar 17 07:02:52 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:02:52 IST: OSPF: rcv. v:2 t:4 l:64 rid:10.130.148.3
      aid:0.0.0.4 chk:B4BD aut:0 auk: from Vlan10
Mar 17 07:02:52 IST: OSPF: Rcv LS UPD from 10.130.148.3 on Vlan10 length 64 LSA count 1
      aid:0.0.0.4 chk:90E1 aut:0 auk: from Vlan20
Mar 17 07:02:52 IST: OSPF: Rcv LS UPD from 10.130.148.3 on Vlan20 length 64 LSA count 1
Mar 17 07:02:52 IST: OSPF: rcv. v:2 t:4 l:568 rid:10.130.148.3
      aid:0.0.0.4 chk:2B99 aut:0 auk: from Vlan20
Mar 17 07:02:52 IST: OSPF: Rcv LS UPD from 10.130.148.3 on Vlan20 length 568 LSA count 15
Mar 17 07:02:53 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:02:54 IST: OSPF: rcv. v:2 t:1 l:48 rid:10.130.240.58
Mar 17 07:02:55 IST: OSPF: rcv. v:2 t:5 l:364 rid:10.130.240.54
      aid:0.0.0.4 chk:7C73 aut:0 auk: from Vlan20
Mar 17 07:02:55 IST: OSPF: rcv. v:2 t:5 l:364 rid:192.168.1.1
      aid:0.0.0.4 chk:B582 aut:0 auk: from Vlan10
Mar 17 07:02:55 IST: OSPF: rcv. v:2 t:5 l:44 rid:10.130.148.3
      aid:0.0.0.4 chk:34D2 aut:0 auk: from Vlan20
Mar 17 07:02:55 IST: OSPF: rcv. v:2 t:1 l:52 rid:10.130.148.3
--More--
EPHRAIM MANI Sun, 03/18/2012 - 23:40
  • Bronze, 100 points or more
Sanjay,
Thanks for your output, can you pleaes facilitate the far end interface status and configuration of both the interfaces.
~EM
Sanjay Shaw Mon, 03/19/2012 - 11:43
Hi Friends,
Please find configuration at both end.
RTRA>
ip address 10.120.106.245 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip ospf network point-to-point
ip ospf cost 10
ip ospf dead-interval minimal hello-multiplier 4
RTRB>
ip address 10.120.106.246 255.255.255.252
ip ospf cost 10
nkarpysh Tue, 03/20/2012 - 08:49
  • Cisco Employee,
Can you please share "show log" and "show int" from the other side. Possibly do similar debug there. For me it looks that there is some packets loss and other side initiate new session. So you may in parallel start considering fiber/transceiver replacement or just start with transceiver re-seat within it's slot and cleaning the fiber. Please also check if there is any optical transmitters/ patch panels in between which can also add to it.
Don't forget to consider the fiber length with type of transceiver used.
Hope this helps,
Nik
Nandan Mathure Tue, 03/20/2012 - 11:43
"ip ospf mtu-ignore "would help . If it doesnt then change ospf network type to broadcast (if thats fine ). Please let me know if this helps.
nkarpysh Tue, 03/20/2012 - 17:38
  • Cisco Employee,
Hey Nandan,
MTU seems to be same as per show int on A side:
sh int g0/49
And debug messages coming from B:
We really need to see what B side says about this neighborship and what debugs are showing. Layer one checks might also be usefull.
NIk
Sanjay Shaw Sat, 09/01/2012 - 08:21
Hi Mates,
Got late to post the answer:
I have removed this command on both end .
------ip ospf dead-interval minimal hello-multiplier 4.
Got rid of this messages,
Again later after few days I thought it was the Hello and dead interval timer value was creating problem so I tweaked it with some higher timer value and finally this has helped me.
----ip ospf dead-interval 12
----ip ospf hello-interval 3.
Thank U all for posting ur findings.
