Cisco 3500XL Fiber Ports
Mar 8th, 2012
I have an old Cisco 3500XL I am using for my home lab, but was wondering can I use the fiber ports to connect to my PC.  I have to correct NIC interfaces but no link indication.  I did make sure the port was no down, but sill not link....
Any idea???  Thanks.
Jason Dance Thu, 03/08/2012 - 20:03
Have you tried switching the fiber strands so they cross over?
-Jason
Leo Laohoo Thu, 03/08/2012 - 20:45
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Your PC has a fibre optic port?  What speed?
Leo Laohoo Fri, 03/09/2012 - 13:44
  • Hall of Fame,
    2017 LAN, Wireless
gig port from the PC
What media type does the PC NIC card support?  Copper or fibre optic?
jwood1650 Mon, 03/12/2012 - 15:20
Fiber, I have the fiber cable installed, but still nothing...not connecting to the switch.  Is there some configuration I need to do on the switch?
Dan-Ciprian Cicioiu Mon, 03/12/2012 - 15:55
  • Gold, 750 points or more
Hi Jonathan ,
Because is a 2 pair fiber - correct me if I'm wrong - I would try to revert on one side the RX with TX ( left with the right ) connectors.
Dan
Reza Sharifi Mon, 03/12/2012 - 16:10
    2017 LAN
Are you using the correct optic on the switch?
if the PC NIC is Multimode, the GBIC on the switch (which is SC type) must also be Multimode. If the PC is Multimode and the GBIC on the switch is Single-mode, you will not get a link light.
Also, are you  using the correct fiber patch cord?  Usually Multimode cable is orange and single-mode is yellow.
Also, are you sure that the PC's NIC is Gig? It may be 100.
Related Content
