Warning message
Configuring CLI view?
Mar 9th, 2012
I'm using Radius (via Windows 2008 NPS) and trying to authenticate a users with privilege 15 which is working and a custom privilege which I need to assign a custom CLI view to as these custom users only needs to be able to:
Show run
Sh ip int bri
sh vlan
shutdown
no shutdown
Is this possible or am I barking up the wrong tree?  I've look at the the CLI view document and it seems difficult to do, can anyone provide an example?
Andy White Fri, 03/09/2012 - 08:52
Thanks, what do most people do then as I'm sure this is a common request with companies having different levels of access for different teams?
IS it better to not use views, but just privileges?
jonny7_2002 Fri, 03/09/2012 - 08:56
I had a little play with this some time ago and you the views are the best way to go about it.
Jon
John Blakley Fri, 03/09/2012 - 09:03
  • Purple, 4500 points or more
No...you'll appreciate views once you start using privilege levels. You should use views...
