Warning message
PIX 515 ver 6.3 (5)
Mar 9th, 2012
I need to make sure that the firewall is listening to accept traffic destined to this address, 10.10.10.4 on port 80, or if it is for  68.179.71.3.  The traffic should be going in and out the same path to avoid asiymetric routing  This not happening because I cannot get traffic through to and from my webserver.  what is the best solution for this isuue?
The ip address outside 10.10.10.1 255.255.255.0
The ip address inside 192.168.1.1 255.255.225.0
The ip range 10.0.10.0 255.255.255.0 cannot get traffice to and from my webserver.
What is the solution to my problem?  Thank you
Fawadnoorkhan_2 Sat, 03/10/2012 - 05:43
kindly provide your running config... you can remove the passwords and change the actual ip address with dummy ones.
Related Content
