Incorrect License State shown on 1 Switch
manju.cisco
Level 3
Level 3
Recently on two switches, both being same cisco WS-C3750E-24PD, running with same IOS c3750e-universalk9-mz.122-58.SE2.bin
got noticed that the license state of one switch is showing incorrectly as shown below
Swithc 1)
     Switch#sh license
     Index 1 Feature: advipservices
             Period left: Life time
             License Type: Permanent
             License State: Active, In Use
             License Priority: Medium
             License Count: Non-Counted
     Index 2 Feature: ipservices
             Period left: 8  weeks 4  days
             License Type: Evaluation
             License State: Active, Not in Use, EULA not accepted
             License Priority: None
     Index 3 Feature: ipbase
             Period left: 0  minute  0  second
     Switch#sh ver
     Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(58)SE2, RELEASE SOFTWARE (fc1)
     License Level: ipservices
     Next reload license Level: ipservices
Question: Though, show license says advipservices is Permanent license and is In Active, why does show license shows level as ipservices as permanent ?? Any thoughts please?
Below is the same thing on another switch being same model and having same ios version and its showing correctly....
Switch 2)
     Switch#sh license
     Switch#sh ver
     License Level: ipbase
     Next reload license Level: ipbase
I will not be able to execute any changes/modifications on switch as of now, and would just need possible thought to identify how this is happening..
Manjunath
9 Replies 9
Reza Sharifi
Hi Manjunath,
Can you make sure to apply this command to the second switch, save and reboot?
config t
license boot level ipservices
Hi Reza,
I believe you meant to execute command "license boot level advipservices" .....advipservices not ipservices..becaues show license says advipservices as permanent.
I believe the command was applied already but got noticed today, but let me reapply it on scheduling a downtime window.
Would there be no other reason you believe ??
Also would like to inform something additional here, a strange thing
under show version and show boot on both switches i see this,
On Switch 1)
     Switch#show version
     [truncated]
     System image file is "9 "
     [truncated]
     Switch#
     Switch#sh boot
     BOOT path-list      : flash:c3750e-universalk9-mz.122-58.SE2.bin
     Config file         : flash:/config.text
     Private Config file : flash:/private-config.text
Switch was rebooted and it wasn't stuck in ROMMON, switch came up and alive but still show version says system image file is "9 " ........ wonder why
on Switch 2)
      Switch#show version
      [truncated]
      System image file is "flash:/c3750e-universalk9-mz.122-58.SE2.bin"
      [truncated]
      Switch#
     Switch#sh boot
Any thoughts again please.....
Manjunath
Message was edited by: Manjunath Shivanna
Hi Manjunath,
This appears to be an issue IOS file being corrupted.  Here is what I would do.  Have an outage window, delete the IOS completely , format the flash card, reload a fresh ver of IOS than reboot.
Question: are these switches stacked? Are you supposed to have permanant "advipservices" license on both switches? I know licensing is a pain, and I had my share of issues with it.
Anyway, if the command above I provided doesn't work, you are going to need a new license key.  When you apply to get a license key, make sure the UID of the switch is exactly what is shows in the sh ver, if not the license does not work.
Hi Reza,
I just verified the IOS md5 signature value, it matches with cisco provided md5 value (c9dcf62d0f86e11d24550925a59fb860).
So, can the IOS still be corrupted ?
NO, its a standalone switch, nothing stacked to it yet...
Manjunath
Hi Manjunath,
Since it passed the MD5 test, than IOS is probably good.  I think, some one has accidentally renamed the IOS name on the flash to "9 ". So, you can try renaming it back or load a new one. As for the license, try the boot command and let me know.  Are these switches stacked?
Reza
Hi Reza,
NO., both are standalone switches at different floor.
Flash is having proper image name, the image name in flash is "c3750e-universalk9-mz.122-58.SE2.bin".
Did no boot system and configured boot system again, and rebooted., still show version shows system image file is "9 "
Crazy IOS isn't it
Crazy IOS isn't it
It is.
I would delete the existing one, download a fresh one from Cisco's site and load it.  Who knows what is going on with the IOS.
Reza
If you do a show flash: do you see the proper image file? Have they implemented secure boot-image on these switches yet?
Kevin Dorrell
Luxembourg
Hi Kevin,
yes, show flash: and show boot points proper image file and secure boot-image is not implemented
Any thoughts again please?
Manjunath
