Warning message
Cisco 871 PPTP VPN Server Setup
Mar 10th, 2012
I am trying to configure a Cisco 871 to act as a PPTP VPN server on my home network. I have referenced Cisco's documentation regarding this which I will include below as well as a copy of my current running configuration and terminal monitor information from when I attempt to establish a connection. If there is any other information I can provide please let me know and I will do so in a timely manner. Thank you for your help.
When I attempt to connect from a Windows machine I receive the following error: 'Error 807: The network connection between your computer and the VPN server was interrupted.' 'The remote device won't accept the connection.'
When I attempt to connect VIA my mobile, I get 'The server has hung up'.
The 871 does detect the incoming connection which can be seen from the terminal monitor output: http://pastebin.com/weqCGweH
Current Configuration: http://pastebin.com/MaWrUZnv
Documentation:
http://www.cisco.com/en/US/products/ps5855/products_configuration_example09186a0080ab7073.shtml
PlumSmuggler Sat, 03/10/2012 - 20:22
I apologize I pasted information from two different 871 setups. I have one at my house and we also set one up in the engineering lab.
I have updated the running config and the terminal output from when the user connects. Thank you and sorry for the mis-information.
I just want to 'repost' the correct information below, this has updated terminal and configuration outputs.
I am still trying to configure a Cisco 871 to act as a PPTP VPN server on my home network. I have referenced Cisco's documentation regarding this which I will include below as well as a copy of my current running configuration and terminal monitor information from when I attempt to establish a connection. If there is any other information I can provide please let me know and I will do so in a timely manner. Thank you for your help.
Documentation:
PlumSmuggler Sat, 03/10/2012 - 21:31
Ok so I have made some progress. Some background.
Updated Config: http://pastebin.com/eZNYcxyu
I have 3 users setup:
- username Smokyo7 secret 5
- username David secret 5
- username test password 0
All users can connect with encryption turned off. Once encryption is enabled the interface goes down immediately after coming up. I will show this in a paste: http://pastebin.com/4VxXBuvq
As you can see the first connection is with encryption enabled and the second attempt is with encryption disabled. The only difference between the two that I can see is the following.
Mar 1 01:13:37.535: Vi3 PAP: O AUTH-ACK id 2 len 5
Mar 1 01:14:09.515: Vi4 PAP: O AUTH-ACK id 1 len 5
I am not sure if this is just the router saying 'ok id 2 drop or id 1 stay'.
Thank you.
