Access-Trunk link issue
Mar 11th, 2012
Dear All,
what happen if two switches connected using utp cable one end configured static access and the other end configured statis trunk ?
and if it will not work why ?
Jan Hrnko Sun, 03/11/2012 - 05:32
  • Silver, 250 points or more
I think that it will work but:
The side that has static access configured will accept only non-tagged frames, because it does not anticipate tagged ones (host side(port) is not even suposed to know in which vlan is he assigned to and host side is not allowed to generate tagged frames). The side that has trunk configured will generate both tagged and untagged frames. As you may know - untagged frames are from hosts that are in the native vlan. So the conclusion is that in such a scenario only hosts in the native vlan would be able to communicate through this link (trunk-access).
Best regards,
Jan
jimmysands73_2 Sun, 03/11/2012 - 08:18
Just a refresher....
DTP Combinations
Figure 1 Administrative Mode Combinations and their Operational Modes Administrative Mode
Auto
Desirable
Trunk (on)
Access (off)
Non-Negotiate (access)
Non-Negotiate (trunk)
Auto
Static access (NT)
Trunk
Trunk
Static access
Static access
Unexpected Results
Desirable
Trunk
Trunk
Trunk
Static access
Static access
Unexpected Results
Trunk (on)
Trunk
Trunk
Trunk
Unexpected Results
Unexpected Results
Trunk
Access (off)
Static access
Static access
Unexpected Results
Static access
Static access
Unexpected Results
Static access
Static access
Unexpected Results
Static access
Static access
Unexpected Results
Unexpected Results
Unexpected Results
Trunk
Unexpected Results
Unexpected Results
Trunk
