NAT Cisco 2901
Mar 11th, 2012
I am attempting to configure a Cisco 2901 router using IOS 15 to   properly perform NAT/PAT translation between LAN and the internet   connection.
My Configuration:
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly
no ip route-cache
duplex auto
speed auto
no cdp enable
no mop enabled
interface ISM0/0
no ip address
no ip route-cache
shutdown
service-module fail-open
no cdp enable
hold-queue 60 out
interface ISM0/1
no ip address
no ip route-cache
shutdown
no cdp enable
interface GigabitEthernet0/1
ip address 10.1.1.1 255.255.255.0
ip nat inside
no ip route-cache
duplex auto
speed auto
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
access-list 1 permit 10.1.1.0 0.0.0.255
But Nat no work
Any ideas?
Overall Rating: 5 (1 ratings)
Ton V Engelen Mon, 03/12/2012 - 03:44
  • Bronze, 100 points or more
is this all the configuration?
For I dont see a nat pool.
Something like this,  where 1.1.1.1 is just an example, replace it with your outside ip address
ip nat pool POOL-NAME 1.1.1.1 1.1.1.1 netmask 255.255.255.240
ip nat inside source list 10 pool POOL-NAME overload
access-list 10 permit 10.1.1.0 0.0.0.255
Jan Hrnko Mon, 03/12/2012 - 05:55
  • Silver, 250 points or more
Hi Ton,
I don't think that the nat pool is necessary because NAT overload (PAT) with overloaded interface is in use here. Therefore all private addresses are translated to Router GigabitEthernet 0/0 interface's address using different ports.
I believe that this is not causing the problem.
Best regards,
Jan
Ton V Engelen Mon, 03/12/2012 - 06:32
Hi, Jan
thanks for pointing out. Guess i needed more coffee this morning...
Jan Hrnko Mon, 03/12/2012 - 07:13
Hi Ton,
you're welcome! Yeah, I think that all of us would appreciate more sleep at night or more coffee in the morning at least . Have a nice day!
Btw, I am really curious what could be cause of the problem here...
Best regards,
Jan
Jan Hrnko Mon, 03/12/2012 - 06:01
I have tried similar configuration as yours (NAT overload, overloaded interface with DHCP assigned IP address) but it works. Are you absolutely sure that NAT is not working correctly? Can't there be any other problem? Please try to verify NAT by using the command: show ip nat translations. Also please check if the Gi0/0 interface has ip address correctly assigned and if the default route is installed in the routing table.
Best regards,
Jan.
Jerson Luiz de ... Mon, 03/12/2012 - 14:42
Hi everyone
My Full Configuration:
Current configuration : 2005 bytes
! Last configuration change at 21:40:23 UTC Mon Mar 12 2012
version 15.1
service config
hostname Volts
boot-start-marker
boot-end-marker
enable secret 5 $1$wB9U$.k3JKiQCsqj6sXs9DW9FN/
enable password blaalalallalaa
no aaa new-model
no process cpu extended history
no process cpu autoprofile hog
no ipv6 cef
ip source-route
no ip routing
no ip cef
ip domain name 192.168.0.1
ip name-server 8.8.8.8
ip name-server 8.8.8.4
voice-card 0
license udi pid CISCO2901/K9 sn FTX153784LL
hw-module pvdm 0/0
redundancy
interface Embedded-Service-Engine0/0
no ip address
no ip route-cache
shutdown
no cdp enable
ip address dhcp
ip nat outside
ip virtual-reassembly in
no ip route-cache
duplex auto
speed auto
no cdp enable
no mop enabled
ip nat inside
no ip route-cache
duplex auto
speed auto
no cdp enable
interface Serial0/0/0
no ip address
no ip route-cache
shutdown
no fair-queue
clock rate 2000000
ip default-gateway 192.168.0.1
no ip http server
ip route 0.0.0.0 0.0.0.0 192.168.0.1 254
snmp-server community public RO
control-plane
voice-port 0/1/0
voice-port 0/1/1
mgcp profile default
gatekeeper
shutdown
line con 0
exec-timeout 0 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password @#in4008@#
login
transport input all
scheduler allocate 20000 1000
end
Jan Hrnko Mon, 03/12/2012 - 15:00
Hi Luiz,
I have just seen the config and I suppose I have an idea what could be causing the problem. PAT is ok, the default route is not.
In the output you have given us earlier was this:
It is ok, it means that all traffic that cannot be routed by routing entries in the table is forwarded using interface Gi0/0
But in the output you have provided now is this:
There is IP address of next hop. Don't you think this is causing the problem? IP of the next hop should be public IP address, not private! So you should use ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 solution or something else but definitely not private IP address if you want to access the internet.
What do you think?
Best regards,
Jan
Jerson Luiz de ... Mon, 03/12/2012 - 15:05
%Default route without gateway, if not a point-to-point interface, may impact performance
Jan Hrnko Mon, 03/12/2012 - 15:33
I see now. So you are using NAT two times? So therefore the problem could be 1. NAT is not working correctly - which I doubt because it seems to be configured properly...or something next on the link is not correct. Would you be so kind and try to ping the IP default gateway 192.168.0.1 from host with IP address of 10.1.1.2? Immediately after that please do show ip nat translations. I forgot to mention that earlier, but if there are not active connections for some time, this command will have blank output.
Best regards,
Jan
Jerson Luiz de ... Mon, 03/12/2012 - 14:44
But nothing, my station with ip 10.1.1.2 dont access internet.
When i putty sh ip nat translation CLI dont return nothing.
Jan Hrnko Mon, 03/12/2012 - 14:50
Hi Luiz,
Please can you verify by command sh ip route that the default route is installed in the routing table and by using command show ip interface gigabitEthernet 0/0 verify the correct state and IP of the interface? Please, if you would be so kind and paste output from these two commands aslo.Thank you!
sh ip route
Best regards,
Jan
Jerson Luiz de ... Mon, 03/12/2012 - 15:03
sh ip route
Default gateway is 192.168.0.1
Host               Gateway           Last Use    Total Uses  Interface
ICMP redirect cache is empty
GigabitEthernet0/0 is up, line protocol is up
  Internet address is 192.168.0.128/24
  Broadcast address is 255.255.255.255
  Address determined by DHCP
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is disabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is disabled
  IP Null turbo vector
  IP multicast fast switching is disabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are None
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is enabled, interface in domain outside
  BGP Policy Mapping is disabled
  Input features: Stateful Inspection, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, NAT Outside, MCI Check
  Output features: Post-routing NAT Outside, Stateful Inspection, NAT ALG proxy
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
Dan-Ciprian Cicioiu Mon, 03/12/2012 - 15:35
  • Gold, 750 points or more
Besides I do not know what kind of internet access do you have , using private IPs ( 192.168.0/24 ) you have a little config issue :
no ip routing
no ip cef
Enable routing and cef :
conf t
ip routing
ip cef
end
wr mem
Dan
Jan Hrnko Mon, 03/12/2012 - 15:40
you are right! I have not seen it in the second configuration posted. It is most likely causing problems.
Best regards,
Jan
Jerson Luiz de ... Mon, 03/12/2012 - 16:20
I do not know what is happening, I have a Cisco 3640 with NAT Running!
Jerson Júnior
Dan-Ciprian Cicioiu Tue, 03/13/2012 - 02:24
Hi ,
please post :
ping 8.8.8.8
show ip route
show ip inter brie
Dan
Jerson Luiz de ... Tue, 03/13/2012 - 16:25
ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/28/44 ms
show ip route
show ip inter brie
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0         192.168.0.128   YES DHCP   up                    up
GigabitEthernet0/1         10.1.1.1        YES NVRAM  up                    up
Serial0/0/0                unassigned      YES NVRAM  administratively down down
NVI0                       unassigned      YES unset  administratively down down
Dan-Ciprian Cicioiu Tue, 03/13/2012 - 16:29
IP routing is not enabled !
Enable ip routing
conf t
ip routing
end
After that , please paste show ip route
Dan
Jerson Luiz de ... Tue, 03/13/2012 - 16:49
ip routing enable but now ping to external not work
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S*    0.0.0.0/0 is directly connected, GigabitEthernet0/0
      192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.0.0/24 is directly connected, GigabitEthernet0/0
L        192.168.0.128/32 is directly connected, GigabitEthernet0/0
Dan-Ciprian Cicioiu Wed, 03/14/2012 - 00:05
That's ok.
You should change the default route
conf t
no ip route 0.0.0.0 0.0.0.0 Gi0/0
end
Try to access the internet. Tell me the result.
Dan
Jerson Luiz de ... Wed, 03/14/2012 - 14:45
Nothing
I have a 3640 an NAT works with this configuration:
interface Ethernet0/0
ip address 10.1.1.253 255.255.255.0
ip nat inside
half-duplex
interface Ethernet1/0
no ip address
shutdown
half-duplex
interface FastEthernet2/0
description ### Internet GVT ###
ip address dhcp
ip nat outside
duplex auto
speed auto
ip default-gateway 192.168.1.1
ip nat inside source list 7 interface FastEthernet2/0 overload
ip nat inside source list 101 interface Ethernet0/0 overload
ip nat inside source static 10.1.1.253 192.168.1.4
ip nat inside source static tcp 10.1.1.253 80 192.168.1.2 80 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
no ip http server
access-list 7 permit 10.1.1.0 0.0.0.255
Dan-Ciprian Cicioiu Wed, 03/14/2012 - 14:49
Please paste "show ip route"  from your Cisco 2901
Dan
Jerson Luiz de ... Wed, 03/14/2012 - 15:12
Hi Everyone
Nat Works Now
Configuration:
ip address 192.168.1.4 255.255.255.0
ip nat outside
no ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
no mop enabled
ip address 10.1.1.254 255.255.255.0
ip nat inside
duplex auto
speed auto
no cdp enable
no ip address
shutdown
no fair-queue
clock rate 2000000
no ip http server
ip nat inside source list 101 interface GigabitEthernet0/1 overload
ip nat inside source static 10.1.1.254 192.168.1.4
Jerson Luiz de ... Wed, 03/14/2012 - 15:35
I think the solution was:
