iBGP vs eBGP
Joe Lee
Understand how iBGP and eBGP work, can anyone tell me what are the pros and cons between these protocols? Any documentation is greatly appriciated.
Joe
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
If you understand how both work, then you realize the determinant is whether to BGP peers are using the same AS or a different AS.  For routine eBGP, you're peers are very likely to use different ASs, so you wouldn't have a choice.  For internal BGP usage, I suppose you could use different (private?) ASs, down to individual BGP peers allowing them to operate with eBGP rules.
The pros and cons of using eBGP internally vs. iBGP would be due to the differences in peering rules and routing rules.  With eBGP rules you don't need to create a full mesh as you do with iBGP (or reflectors or confederations).  With eBGP rules, you're less likely to require another IGP if the peers share a common subnet, or if they don't, need special multi-hop configuration along with extra routing information external to BGP itself.  With eBGP rules, AS hops might indicate actual best path.
Although in theory I guess you could use eBGP rules with private ASs within the same logical AS, it could make it difficult to peer with more then one external public AS.  In other words, this isn't normally a choice, so curious how you envisioned using pros and cons to select between eBGP vs. iBGP.
PS:
NB: "***" = Plural of AS - AS.s (sigh - politically correct word filtering)
6 Replies 6
Reza Sharifi
Hi Joe,
IBGP is usually is used within an autonomous system. It is basically Internal BGP vs EBGP is used for one autonomous system to connect to another autonomous system (External BGP).
http://www.skullbox.net/bgp.php
Hi Joe,
Each other are there for different aspects.
iBGP is to serve within AS where eBGP is to serve between different autonomous system.
If an AS has multiple BGP speakers, the AS can serve as a transit service for other ASs.
Please rate the helpfull posts.
Naidu.
Joseph W. Doherty
Disclaimer
Posting
PS:
milan.kulik
Level 10
Level 10
there is only one protocol in fact - BGP.
There are just eBGP and iBGP neigbors.
And different rules how prefixes received from  eBGP/iBGP are treated and sent to other neighbors.
See
http://www.cisco.com/en/US/customer/tech/tk365/technologies_q_and_a_item09186a00800949e8.shtml#nineteen
for examples.
HTH,
Milan
4 years old - WOW
Is there a different site people are going to now?
Oh yeah - I agree with Milan.
Postings on this site go back much further than even 4 years; mine go back to 2007, some other still active posters go back several years further.
