phones settings restrictions in callmanager Express
Answered Question
Mar 12th, 2012
is it possible to restrict the phone settings at callmanager express for end users like in communications manager, so that
the users have not access to settings at the phone via the settings button and cannot change ringtones etc.
Correct Answer by Rob Huffman about 5 years 1 month ago
Hi SA,
There is a similar method for CME that may help;
settingsAccess {0 | 1 | 2}
Enables and disables the Settings button on an IP phone.
0-Disabled.
1-Enabled (default). The phone user can modify features by using the Settings menu.
2-Restricted. The phone user is allowed to access User Preferences and volume settings only.
service phone
To modify the vendorConfig parameters in the configuration file, use the service phone command in telephony-service or ephone-template configuration mode. To disable a setting, use the no form of this command.
service phone parameter-name parameter-value
Router(config)# telephony-service
Router(config-telephony)# service phone
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_s1ht.html#wp1083963
Cheers!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Mon, 03/12/2012 - 05:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi SA,
0-Disabled.
service phone
Cheers!
Rob
Related Content
