Is CUOM 2.3 able to Support CUCM 7.1.5
Mar 12th, 2012
  I am looking at the supported CUCM by CUOM 2.3 at the following link:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_unified_operations_manager/2.3/device_support/table/OMdvs23.html#wp97691
The supported CUCM version are 4.1, 4.2, 4.3, 5.0, 5.1, 6.0, 6.1, 7.0(1), 7.0(2), 7.1(2), 7.1(3), and 8.0.
  Not sure if the link has been updated.  Does CUOM 2.3 support CUCM 7.1(5)?  Or do we have to upgrade it to CUOM 8.0?
Daniel
Michel Hegeraat Tue, 03/13/2012 - 04:59
  • Gold, 750 points or more
The safe way is to get the SysObjectID of the callmanager using an SNMP walk.
D:\CSCOpx\objects\jt\bin\snmpwalk.exe -c -v 2c 1.3.6.1.2.1.1.2.0
If it is in the supported devices list thatn you are good, if not upgrade to CUOM.8.6
Cheers,
Michel
