Warning message
nexus 7000 redistribute ospf summary subnet
Mar 12th, 2012
I have a Nexus 7K router, has 2 ospf process, ospf 1 and ospf2. OSPF1 has several subnets in 10.1.0.0/16 subnet range , OSPF2 has several subnets in  10.2.0.0/16 subnet range. I want to summary OSPF 1 subnets to 10.1.0.0/16 then redistribute to OSPF2.but OSPF 2 didn't receive 10.1.0.0/16. Below is the config
ip prefix-list all seq 10 permit 0.0.0.0/0 le 32
route-map all permit 10
  match ip address prefix-list all
router ospf 1
  router-id 10.10.3.9
  summary-address 10.20.0.0/16 not-advertise
router ospf 2
  router-id 10.10.3.1
  redistribute ospf 1 route-map all
Richard Burts Mon, 03/12/2012 - 11:46
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
This is an exact repeat of a post that you submitted in the WAN Routing forum. If you are going to repeat a post you could at least acknowledge that it is a repeat from another forum. I suggest that any discussion of this question be consolidated in the WAN forum.
Rick
yang.yutd Mon, 03/12/2012 - 12:01
The IP scheme was changed, but still the same issue, below is the info that you reqeust:
ip prefix-list any seq 5 permit 10.20.0.0/16
route-map any permit 10
  match ip address prefix-list any
router ospf 1
  router-id 10.10.3.2
router ospf 2
  router-id 10.10.3.10
  redistribute ospf 1 route-map any
NCOREadminLAB2-NCORELAB2# sh ip ospf 1 summ
             OSPF Router with ID (10.10.3.2) (Process ID 1 VRF default)
Configured summary-address
10.20.0.0/16 Pending
NCOREadminLAB2-NCORELAB2# sh ip ospf 1 database are 1
                Router Link States (Area 0.0.0.1)
Link ID         ADV Router      Age        Seq#       Checksum Link Count
10.10.3.2       10.10.3.2       1307       0x80000687 0xda96   1
                Summary Network Link States (Area 0.0.0.1)
10.4.1.0        10.10.3.2       636        0x80000506 0x28e5
10.4.1.16       10.10.3.2       636        0x80000506 0x8776
10.4.1.32       10.10.3.2       636        0x80000681 0xec84
10.4.1.48       10.10.3.2       636        0x80000506 0x4697
10.4.1.64       10.10.3.2       636        0x80000506 0xa528
10.4.1.80       10.10.3.2       636        0x8000068a 0xf83f
10.4.1.96       10.10.3.2       636        0x80000506 0x6449
10.4.1.112      10.10.3.2       636        0x80000681 0xc957
10.4.1.128      10.10.3.2       636        0x80000506 0x236a
10.4.1.144      10.10.3.2       636        0x8000068a 0x7681
10.4.1.160      10.10.3.2       636        0x80000506 0xe18b
10.4.1.176      10.10.3.2       636        0x8000068a 0x35a2
10.10.1.0       10.10.3.2       586        0x800004ac 0x4838
10.10.1.8       10.10.3.2       596        0x80000505 0x44da
10.10.1.16      10.10.3.2       626        0x800004ac 0x93de
10.10.1.24      10.10.3.2       1377       0x800004d4 0xf24f
10.10.1.32      10.10.3.2       476        0x80000501 0x33db
10.10.1.48      10.10.3.2       1257       0x80000685 0x7cfd
10.10.1.120     10.10.3.2       636        0x80000506 0x5b2c
10.10.2.0       10.10.3.2       636        0x80000506 0xd432
10.10.2.16      10.10.3.2       636        0x8000068a 0x2849
10.10.2.32      10.10.3.2       636        0x80000681 0x99d0
10.10.2.48      10.10.3.2       636        0x8000068a 0xe66a
10.10.2.64      10.10.3.2       636        0x8000068a 0x46fa
10.10.2.80      10.10.3.2       636        0x80000681 0xb782
10.10.2.96      10.10.3.2       636        0x80000506 0x1195
10.10.2.112     10.10.3.2       636        0x80000681 0x76a3
10.10.2.128     10.10.3.2       636        0x80000506 0xcfb6
10.10.2.144     10.10.3.2       636        0x80000506 0x2f47
10.10.2.160     10.10.3.2       636        0x80000681 0x9455
10.10.2.176     10.10.3.2       636        0x80000681 0xf3e5
10.10.3.3       10.10.3.2       626        0x80000507 0x7c9d
10.10.3.4       10.10.3.2       636        0x8000068a 0x682c
10.10.3.5       10.10.3.2       1257       0x80000685 0x4a51
10.10.3.9       10.10.3.2       426        0x80000502 0x36e4
10.10.7.0       10.10.3.2       1377       0x80000504 0xa956
10.20.1.0       10.10.3.2       1257       0x80000685 0xbfe7
10.20.1.16      10.10.3.2       1257       0x80000685 0x1f78
10.20.1.32      10.10.3.2       1257       0x80000685 0x7e09
10.20.1.48      10.10.3.2       1257       0x80000685 0xdd99
10.20.1.64      10.10.3.2       1257       0x80000685 0x3d2a
10.20.1.80      10.10.3.2       1257       0x80000685 0x9cba
10.20.1.96      10.10.3.2       1257       0x80000685 0xfb4b
10.20.1.112     10.10.3.2       1257       0x80000685 0x5bdb
10.20.1.128     10.10.3.2       1257       0x80000685 0xba6c
10.20.1.144     10.10.3.2       1257       0x80000685 0x1afc
10.20.1.160     10.10.3.2       1257       0x80000685 0x798d
10.20.1.176     10.10.3.2       1257       0x80000685 0xd81e
10.55.1.0       10.10.3.2       1257       0x80000685 0x6216
20.20.20.0      10.10.3.2       636        0x80000506 0x6d64
30.30.30.0      10.10.3.2       636        0x80000683 0x062f
40.40.40.0      10.10.3.2       636        0x80000506 0x9afa
NCOREadminLAB2-NCORELAB2# sh ip ospf 2 database external
        OSPF Router with ID (10.10.3.10) (Process ID 2 VRF default)
                Type-5 AS External Link States
Link ID         ADV Router      Age        Seq#       Checksum Tag
10.10.1.0       10.10.3.1       926        0x800004a8 0x5a92    0
10.10.1.8       10.10.3.1       926        0x800004a8 0x0ada    0
10.10.1.32      10.10.3.1       926        0x800004a8 0x19b3    0
10.10.3.9       10.10.3.1       926        0x800004a8 0x14c6    0
10.10.7.0       10.10.3.1       926        0x800004a8 0x18ce    0
