How to tell which side ended a call
Mar 12th, 2012
I'm trying to log on a syslog server mainly which side initiated a request to end a call on an h323 gateway.  I would run that continously and save it.  What's the best debug command for that?  I don't want big long outputs such as q931 if I can avoid it.  Just something short and concise.  I was hopping it was in
%VOIPAAA output on the router, but unless I'm missing something, it's not in there.
Thanks in advance for your input.
paolo bevilacqua Tue, 03/13/2012 - 09:43
  • Hall of Fame,
    Founding Member
Try conf t
aaa accounting connection h323 start-stop group radius
gw-accounting syslog.
If that doesn't do for you, try cch323 debugs.
