Cisco 1841 Serial interface issue
Mar 13th, 2012
i have one problem in my client end router(cisco 1841).
In that they have leased line with 128 kbps.
But the link is down.
I take the router through console for troubleshooting.
while i check with the serial interface they show output like this.
Serial0/1/0 is down, line protocol is down
  Hardware is GT96K Serial
  Internet address is 192.168.35.125/30
  MTU 1500 bytes, BW 128 Kbit, DLY 20000 usec,
  Encapsulation PPP, LCP Closed, loopback not set
  Keepalive set (10 sec)
  CRC checking enabled
  Last input never, output 00:07:21, output hang never
  Last clearing of "show interface" counters 00:16:13
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     27 packets output, 378 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     12 carrier transitions
     DCD=down  DSR=up  DTR=up  RTS=up  CTS=up
If DCD down means how to troubleshoot?
what is DCD??
can anyone tell me where is the issue.
Overall Rating: 5 (1 ratings)
Dan-Ciprian Cicioiu Tue, 03/13/2012 - 02:40
  • Gold, 750 points or more
Hi ,
DCD means carrier detect , so in your case there is no carrier.
The issue is the link. If the link is offered by a provider I would ask them to check the circuit.
Dan
kumarpmt83 Tue, 03/13/2012 - 02:44
if it is chance have any problem in serial cable or modem.
Dan-Ciprian Cicioiu Tue, 03/13/2012 - 03:28
I do belive that the circuit is the problem. As far as I know:
    DSR is the terminal ready , in you case up , the router receives the modem ready , so the serial cable is not the problem
    DCD down means that the local modem cannot communicate with the other end modem.
Dan
kumarpmt83 Tue, 03/13/2012 - 04:54
Thanks for ur Information.
In case any modem or serial cable problem means which of the parameter to be down.
How to find that.
Dan-Ciprian Cicioiu Tue, 03/13/2012 - 05:13
Hi ,
DCD, CTS , DSR - are provided by the dce in your case the modem
DTR , RTS - are provided by the dte in your case the router.
If CTS and DSR are down and DTR and RTS are up ,this can be a modem or a cable problem.
Dan
